Old 10-16-2020, 12:03 PM   #1
RPH
Drives: Toyota Yaris XP9 1.3 VVT-i
Possible clutch actuator problem
Hi,
A couple of months ago I bought a Toyota Yaris MK2.
Some times after driving for a bit and stop for e.g. a trafficlight, I get a constant beeping sound.
It stops when I start driving again.
It's exactly the sound from this video:
https://www.youtube.com/watch?v=aP4n5Cknh20
Is it correct that I probably need to have the clutch actuator replaced?
RPH is offline   Reply With Quote
Old 10-17-2020, 10:54 AM   #2
RPH
- Checked the battery, it's a new one. No problem. About 12.8v engine OFF, around 14.2/14.4v engine ON. Wire connection seems to be OK.
- Checked the fuses in the engine compartment with a multi-meter (Ohms and Volts). All are OK.
- The battery ground is connected to the chassis, do not see something odd.
- Used an OBD2 connector to check for faultcodes, none thru two different OBD scanner apps (Torque and Car scanner).
Old 10-17-2020, 11:11 AM   #3
Someone posted a thread quite some time ago inquiring how to disable that beeping. I believe in his case, he was referring to an alarm triggered by a proximity detector, detecting something to close to the front of the car at a stop.
Old 10-17-2020, 11:15 AM   #4
Found it.
Unfortunately no confirmed resolution.
https://www.yarisworld.com/forums/sh...hlight=Disable
Old 10-18-2020, 10:25 AM   #5
RPH
Hi,
Thanks for the reply, maybe I should have added some more information.
- It's a secondhand Toyota Yaris from 2006, don't think it has a proximity sensor.
- The beeping also happens when there is no car in front of me.
Today:
- Removed all the fuses and sanded them, to make the connection better. And placed them back.
- Used contact spray in all slots.
- Removed the minus pole from the battery and sanded it, did the same to the ground connected to the chassis. And placed it back.
Old 10-18-2020, 04:29 PM   #6
Apparently European market MK2 2006 could have sensors installed.
https://www.yarisworld.com/forums/sh...ad.php?t=57270
Old 10-19-2020, 11:49 AM   #7
RPH
I see, a genuine Toyota accessory apparently.
My car doesn't have it AFAIK, no beeping when close to something.
Old 12-18-2020, 04:18 PM   #8
RPH
Shame I got no other replies about this problem.
The beeping can also be stopped by shifting manually from one to two, after a while it starts again. Then I shift back to one.
It must be a problem with the clutch actuator motor.
Old 02-14-2021, 07:28 PM   #9
stigva
Drives: yaris
Sir,
Thanks for bringing this to general attention.
Corolla 1.3 VVT 2006, manufactured in France, here...
Humbly, i have exact same problem early last year. Didnt beep at first. Car just stopped-and-wouldnt-start when driving slowly in queue. After some time, the defective gear-control burned out my clutch discs. It was only beeping at the very end and... Well, I thought it was just defective physical clutch. Ok. Had just the clucth plates replaced. But only to get exact same problem now again... 1 year later. It was the other car parts, I suspect
Besides the beeping, you gotta smell carefully for burnt clutch, please.
Sir, please watch (I know, slightly other model, but setup and year looks very similar to me):
https://www.youtube.com/watch?v=lsbh...=LMAutoRepairs
This problem can originate from either of reasons :
- bad relay
- bad transmission control computer box (located behind glove department)
- bad automat-clutch motor
- it might even mean that your gearbox is leaking oil, I personally had that experience for a short period
- or it could even be some error in the transmission rotation-sensor
without proper error-diagnostice, we will replace parts in the blind. Please read comments in video above and notice gentleman, who replaced all gear-motor-control-parts and things still didnt work...
Back to basics - if it's beeping, it may be an electronics issue or at least detected by electroncs. It's not just some physical defect, which goes unnoticed. Doing a short test by applying manual gear selection may help to determine if this an automat-issue only. Going for the relay also allow for an easy replacement-test. Good luck - I will have to figure out myself what is the real reason for my cluctch-beeping noise. Starts after approx 10 min idle engine - with no attempt to change gear. It's 5 beeps - followed by 6 beeps then 5 beeps... Burnt clutch. For more information, I found this useful:
https://pmmonline.co.uk/technical/th...-and-function/
fuse box layout
https://fuse-box.info/toyota/toyota-...uses-and-relay
watch out for R2 and number 21... Also, on ebay I searched for : Toyota VCI Mini Scanner -- and I'm buying one. After all, this is just one step up from doing OBD codes - gotta try this out. Only problem is that shipping from china takes ages.
I hope this will all help people, who will run into this in the future.
Seriously - this is a Toyota factory quality issue - diagnosis shouldnt be that hard also. Doing beeps and not delivering error code is just genuine bad customer-service.
regards
stigva is offline   Reply With Quote
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
