Old 11-13-2020, 06:00 PM   #1
June yaris
Drives: 2013 Toyota yaris
Idle problem...
Hi there.. I would like to ask if some body experience a high rpm at could start.. I have a 2012 toyota yaris 1nz fe engine.. at could start it run 1600rpm then it after while (3-5min) it goes down to 800rpm.. but before it's not like that it was only 1000rpm at cold start then goes down after 30 sec.. what do you think is the problem.. thanks you!
June yaris is offline   Reply With Quote
Old 11-19-2020, 10:33 PM   #2
toyotavios_11
Drives: Toyota Vios
cold start easily hits 1600rpm-1900rpm, it is normal
toyotavios_11 is offline   Reply With Quote
Old 11-24-2020, 03:20 AM   #3
jng
Drives: 1NZFE NCP93 (Vios)
I'll be worried if it's at 1000rpm during cold start, probably it would take a long time to warm up.
jng is offline   Reply With Quote
Old 12-03-2020, 11:58 AM   #4
IndestructibleYaris
Mine has always done 1500 rpm startup and cools down to 500 after a couple minutes
IndestructibleYaris is offline   Reply With Quote
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Is this idle characteristic a problem? Shinare DIY / Maintenance / Service 11 01-16-2012 07:02 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
