Old 12-23-2020, 07:22 PM   #1
sacklunchz
Drives: 07 yaris
Help confirm C-One springs/shocks install?
Hey all,
I just installed C-One springs and shocks on my 07 yaris sedan.
The install went fine, I think. But I'm a bit nervous that
a) the springs seem fine on the lift with the car in the air (here), but once lowered seem quite compressed (here).
b) the top mount plate/screw seems slightly raised (here). Unlike the stock shocks with the allen-key, the C-One shocks (KYB's apparently) have these plastic tips in the tops of the bolts (which are maybe used to adjust the stiffness? I need to check with C-One on this). I tightened the top nut as much as possible before the shaft started spinning. Is this okay? Or is there a way I need to hold the shaft while tightening the nut (there doesn't seem to be an alley-key hole like the stock shocks)?
I'm pretty confident I installed the proper pieces, but perhaps I missed something? I took the car for a quick drive and it seems to drive fine.
Help?? Thanks ya'll :)
sacklunchz is offline   Reply With Quote
Old 12-23-2020, 07:58 PM   #2
The top mount not making contact with the sheet metal us normal. That is exactly the way it sits with factory suspension installed. Compression is fine as well.
Old 12-23-2020, 08:10 PM   #3
sacklunchz
Drives: 07 yaris
Thank you! That makes me feel much better to know I didn't mess something up. :)
Old 12-23-2020, 10:05 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I agree with WeeYari that the upper strut mount washer does not contact the strut tower under load. The rubber strut mount compresses, allowing the upper part of the shaft and nut to poke up a bit. I can't say, though, that that coil looks normal. It looks too compressed. Any chance of a more perpendicular shot? Are the coil loops actually touching? They appear to be. Looking at the product page, it almost appears that the rear springs were installed on the struts.
Old 12-23-2020, 10:15 PM   #5
sacklunchz
Drives: 07 yaris
Originally Posted by 06YarisRS View Post
I agree with WeeYari that the upper strut mount washer does not contact the strut tower under load. The rubber strut mount compresses, allowing the upper part of the shaft and nut to poke up a bit. I can't say, though, that that coil looks normal. It looks too compressed. Any chance of a more perpendicular shot? Are the coil loops actually touching? They appear to be. It almost looks like the rear springs were installed on the struts.
I think you're right about the springs being on the wrong side. That would explain the problem! Looking at the springs from C-One (these are the actual ones I bought), I see that the ones with the tighter coils are next to the rears...So, yes, I will be swapping them tomorrow. Thanks for noticing that!
Old 12-23-2020, 10:17 PM   #6
06YarisRS
No prob. I would confirm with C-one first to be sure. It's just my observation that they seemed to swapped front to back. The rear is a lot lighter and, as such, the springs wouldn't compress as much.
Old 12-23-2020, 10:20 PM   #7
sacklunchz
Drives: 07 yaris
I emailed them and ill let you know what they say. But honestly I think it's almost certain you're correct. I've installed a dozen or so aftermarket springs and never seen the coils so tight. It's easy enough to swap one side and see.
thanks again friends!
Old 12-23-2020, 10:25 PM   #8
sacklunchz
Drives: 07 yaris
Some pics to lighten my mood! Some Volk CE28s, 14 in +38, 185/60/14
https://imgur.com/a/55A4bbd
Old 12-23-2020, 10:50 PM   #9
06YarisRS
Those are such great looking wheels. I've seen them on a number of Yari and they always look so good. BTW, my brother lives in Durham and works for Duke. He's a flight nurse.
Old 12-24-2020, 04:47 PM   #10
sacklunchz
Drives: 07 yaris
Figured it out. The springs were on the ride ends, but they were upside down! All is well now. Thanks ya'll :)
Old 12-25-2020, 08:10 PM   #11
06YarisRS
Great to hear!
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 01:42 AM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 06:15 PM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 06:18 PM
