Old 03-01-2021, 05:09 AM   #1
Drivel
Drives: 2007 Base Sedan
Question Torque Specs 'document' for ALL common jobs?
I've recently acquired a 2007 Yaris Base Sedan automatic, gratis. It runs and doesn't appear to leak anything, but requires a lot of work (eg: the brakes are shot & other maintenance through the years looks 'spotty').
Given there does NOT appear to be a Haynes or Chilton manual that covers this particular year/model, is there a "summary document" ANYWHERE that gives ALL the correct tightening torques for all the "common jobs"?
By common jobs, I mean everything short of an engine or transmission system teardown or rebuild - though of course, there'd be no objection were those included. Or, if you like, jobs that can be done with just simple common tools in a home garage, no engine hoists or other 'fancy' stuff - just jack-stands, wrenches & the like.
It would be nice to be able to just have one place to go to, one document or even just one or a couple of sheets of paper to refer to, to quickly find these torques.
Some examples of common jobs I have in mind are:
1. Brake refurbishment, pads, any other worn out brake stuff, so all related torque specs required: wheel cylinder attachment bolt, bleed nipple, caliper attachment bolts etc.
2. (Automatic) transmission service, torques for pan bolts and drain plug, filter bolts & ditto for the oil pan & drain plug.
3. Torques for suspension items; strut replacement & so on ...
Thanks in anticipation of useful replies!
Drivel is offline   Reply With Quote
specifications, torques
Motor mount bolts torque specs? AT, back "dog bone" seatech30 DIY / Maintenance / Service 18 10-05-2023 10:17 PM
Front Lower Arms and Ball Joint Torque Specs for 2012 Toyota Yaris LE Hatchback ToughGuy DIY / Maintenance / Service 0 12-23-2020 08:38 PM
Brake caliper torque specs? imopxn DIY / Maintenance / Service 5 08-26-2019 02:13 AM
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 03:36 PM
Suspension Torque Specs pls nisyota Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-21-2010 07:04 AM
