Old 03-02-2021, 04:32 AM   #1
Shak
Drives: 2009 Toyota Yaris YRS sedan
Exclamation Speedometer slow Issue
My speedometer is always around 5-8 km slow.
Struggling infront of cameras specially , ended up slowest car in the road since not sure what kind of speed I am driving.
Any help on this please ? Thanks in advanced.
Shak is offline   Reply With Quote
Old 03-02-2021, 05:44 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The response from Toyota will be "this meets Australian Design Rules".
ADRs allow the speedo to read 3 percent plus 4 km/h higher than the actual speed but must not read lower. This is tested at several specified speeds.
I have the same error in my Yaris. Interestingly, the data from the OBDii port agrees with GPS speed readings.
I have asked a few time on the forum before, but no one seems to have determined if the speedometer has any internal calibration adjustments.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 03-03-2021, 01:15 PM   #3
Mister
Drives: Yaris T1
'Muricah vs Ozstraylyaa...
https://www.youtube.com/watch?v=7n6DEYqVDEY&t=4s
https://www.youtube.com/watch?v=XpA57X4Em8Y
Who wins?
Mister is offline   Reply With Quote
Old 03-03-2021, 04:40 PM   #4
David C
Drives: White '07 3dr LB
Only quick fix would be to swap in bigger outer diameter tires to match the speedometer and odometer, at least on the front wheels.
My Michelin Defender in 185/60/R15 actually gives me 3.5% above the speedometer reading while my Gislaved Nordfrost in 175/65/R14 give me 0.5% below reading.
I haven't thought about cross referencing the OBDII port with GPS data. What I did was log both GPS speed and distance on a 200km stretch of uninterrupted driving with low traffic to log a constant GPS speed of 100km/h on cruise control along with the GPS odometer and timer and the road side mile markers, and compare to the car odometer reading.
So in your case you'd want bigger tires, like a 195/55/R15 instead of a 185/60/R15. You can find data online that would tell you how many revolution per miles or KM your current tire is spec at and use that to determine how many more RPM your bigger tire would need to be to match your speedometer. For example my Michelin Defender was spec at 876 revolutions per miles and the new tire I'm buying this spring is also rated at 876 RPM (BFG Advantage T/A Sport in same size).
David C is offline   Reply With Quote
Old 03-06-2021, 04:30 PM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
Yeah the GPS speed readings on my phone & OBD2 port are the same too with around 1 sec lag from phone. Previously someone explained to me that the issue is that our speedometer is analogue and it does not display the info accurately.
Fluxtasy is offline   Reply With Quote
speedometer, speedometer problem
Speedometer issue: Cluster shows 2X true speed w speed limitation at 95 km/h (190km/h vince90ca General Yaris / Vitz Discussion 0 02-17-2021 11:45 PM
Inaccurate analog speedometer JudgeM DIY / Maintenance / Service 2 12-23-2014 06:00 PM
Analog Speedometer instead Digital Sesjusz DIY / Maintenance / Service 7 07-01-2014 12:42 PM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 05:20 PM
