Old 07-04-2021, 11:04 AM   #1
mertagnan
Drives: Toyota Yaris 2003
Help axle stand crumpled some undercarriage
Hello,
I put my 2003 Yaris on axle stands for the first time and was unsure where the reinforced points were. It looked like a point juts down behind each front wheel, so I tried there, but it crumpled.
Here are photos showing https://photos.app.goo.gl/agBnkJHAafBcBfon6
1) The non-crumpled passenger side which held an axle stand fine
2 and 3) The crumpled driver side where the undercarriage crumped a bit
I would like to ask if this needs urgently fixing, or if it's not too urgent.
Also is this something I can repair or fix myself, or would it require a professional?
Thankyou!
mertagnan is offline   Reply With Quote
Old 07-04-2021, 12:34 PM   #2
bronsin
bronsin's Avatar
You definitely need to have it looked at that’s some pretty serious rust there. I can’t tell from the pictures if it’s safe to drive the car. I drove VW beetles in the 60s and 70s and some of them were really badly rusted, but I knew they would not fail.
These pictures I just don’t feel qualify to assess what the pros do it
Old 07-04-2021, 04:21 PM   #3
mertagnan
thanks
Okay thanks, must have been all those years of wheel spray that weakened it to this point, thanks I will not try a DIY fix then.
axle stand, diy, repair, undercarriage
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
Shorter driver's side cv axle tmontague DIY / Maintenance / Service 2 05-02-2017 02:38 PM
Request: Picture of the transmission end of passenger CV axle WildChild DIY / Maintenance / Service 2 06-16-2014 12:35 PM
2007 yaris cv passanger axle and cardone select cv axle picture ) yaris4062007 DIY / Maintenance / Service 22 04-15-2013 04:35 AM
