Old 06-10-2007, 12:17 AM   #1
Jerkratt
Jerkratt's Avatar
Radiator cap.... answer asap if possible
not sure if this is the right place to post but move it if need be. i was wondering what is the cap pressure? on them cause i wanna get a diffrent one but i dont know what the psi is
"It hurts more when its wet"
Old 06-10-2007, 12:20 AM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
i would answer if I knew...
-- Blen
Old 06-10-2007, 12:20 AM   #3
Jerkratt
Jerkratt's Avatar
wow fast responce.... lol im looking in the online manual for answer also lol
Old 06-10-2007, 02:11 AM   #4
acdaazn
Drives: Toyota
If I am not mistaken, the number on your stock cap tells you the pressure.
Edit: I think it's 1.1 kg/cm^sq. The only place I have seen a TRD 1.1 cap is at trdsparks. Make sure it's type-N, not S.
acdaazn is offline   Reply With Quote
Old 06-10-2007, 05:59 AM   #5
Jerkratt
Jerkratt's Avatar
ok understood. now my second question is the TRD booklet says that there Radiator cap for the yaris is 18.5 thats a big jump from the stock 1.1 no?
Old 06-10-2007, 06:04 AM   #6
ism3t
YarVitz
ism3t's Avatar
Drives: 07' Yaris Liftback
the good news is, i am a math major, so gimme a min...
18.5-1.1=....carry the 5....divide the cosigns...yeah
yeah its 17.4 better. I'd say go for it.
ism3t is offline   Reply With Quote
Old 06-10-2007, 07:37 AM   #7
Jerkratt
Jerkratt's Avatar
i ment in effect to the engine... well cooling system. can it do more harm then good?
Old 06-10-2007, 01:08 PM   #8
acdaazn
Drives: Toyota
If you are in NJ, I wouldn't bump the cap pressure. Afterall, you didn't mod your engine to run super rich, and the winter might cause over-cooling during start-ups.
Old 06-10-2007, 01:31 PM   #9
ricky2k1
Drives: Black YARIS RS
the pressure on the cap is rated in bars
ricky2k1 is offline   Reply With Quote
Old 06-10-2007, 02:54 PM   #10
acdaazn
Drives: Toyota
Just to clarify some convertion.
Bar = kg/sq.cm psi = lb/sq.in
1.1 kg/sq.cm = 15.9 psi
1.3 kg/sq.cm = 18.85 psi
Old 06-10-2007, 03:58 PM   #11
Jerkratt
Jerkratt's Avatar
ahhhh ok thanks
Old 06-10-2007, 04:49 PM   #12
ricky2k1
when the engine gets hot, coolant builds up pressure. the cap just relieves some of the pressure and puts it in the overflow tank. when it cools down it goes back into the radiator. If u decide to let the engine build up some more pressure than recommended, i think your gonna see some leaks somewhere (ie. water pump)
Old 06-10-2007, 10:59 PM   #13
Jerkratt
Jerkratt's Avatar
icic ok thanks
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
NEED HELP ASAP JDM Tails Install PLZ MrMondayNite DIY / Maintenance / Service 6 04-14-2007 06:54 PM
Need some advice! i want my yaris asap :) yup101 General Yaris / Vitz Discussion 3 01-15-2007 08:43 PM
need a fast answer from you pro's silverRS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-14-2006 12:57 AM
How to disable the beep? (ASAP) Rahxephon General Yaris / Vitz Discussion 16 06-05-2006 05:03 PM
