#1 |
![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
1NRFE Spark Plug SC16HR11 Recommendation Pls
Hi
The car has only done 50k 1NRFE Engine I have taken out spark plug and cleaned them with cleaner due to lack of power sometime. Can anyone help if they need replacement No codes No DTC No stalling No shaking Car runs fine however i noticed on torque software misfire count so i am bit confused any recommendation would be highly appreciated. |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
ignition coils work in tandem with your plugs so check them on the particular cylinder with misfire.
#3 |
![]() ![]() Drives: VERSO S Join Date: Jul 2021
How can I test the coils than ?
| Replacing spark plug wire with bell wire | bronsin | Off-topic / Other Cars / Everything else Discussions | 1 | 11-11-2020 01:17 PM |
| bit of spark plug insulation may have fallen into cylinder | alagappan the proud | DIY / Maintenance / Service | 20 | 01-09-2014 06:10 PM |
| Spark plug replacement | vinny121 | DIY / Maintenance / Service | 3 | 08-29-2013 12:25 PM |
| Spark plug Question please :) | lamadoo | DIY / Maintenance / Service | 8 | 04-08-2013 11:55 AM |
| How hard I should try to remove spark plug | mf4361 | DIY / Maintenance / Service | 24 | 03-30-2013 02:07 PM |
