View Poll Results: What do you think of frame braces
Frame braces work and improve handling of a Yaris. 1 100.00%
Frame braces are not effective on a Yaris. 0 0%
Voters: 1. You may not vote on this poll
Old 04-02-2022, 09:19 AM   #1
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Suspension part interchangeability for 2015 5 door hatch back
Hello
Does anyone have any idea about part interchange ability between yaris generations?
I have a 2015 and nobody has aftermarket frame braces or strut/ shock tower braces. The pics look the same except for the mounts on the shocks.
I would love to start a sticky on parts interchangeability.
First example is the sway bar from the 2013. The PTR11-52071 is supposed to bolt right up. I am installing one on my 2015 Le 5 door hatch.
What else can I get away with?
Calrenman is offline   Reply With Quote
Old 04-02-2022, 08:46 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Pretty much anything suspension-wise from a 2nd gen(06-11) will bolt into a 3rd gen hatchback(12-19).
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 04-03-2022, 01:23 AM   #3
Calrenman
Are the shock and shock mounts the same or different>
Thanks Mitch.
I thought the shock mounts and front strut tower are different (I want to install a strut tower brace.).
Old 04-03-2022, 06:27 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Originally Posted by Calrenman View Post
Thanks Mitch.
I have a Tanabe strut bar ready to go onto my car next weekend when I swap onto my summer wheels and the part number is the same between the NCP91(2nd gen hatch) and NCP131(3rd gen).
2014 NCP131 5 Speed
Old 04-05-2022, 02:56 AM   #5
Calrenman
Nice
Let me know how it works. I have not purchased the strut bat yet.
I am looking at the "Front Strut Bar for 2006-2020 Toyota Yaris XP90 XP150 1.5 Hatchback Ultra Racing" (link below). Have you had any experience or heard any reviews with this company's gear? The braces look stout!
I put a "horn brace" and a urethane suspension on my hatch back 3cyl./5 speed 1998 GEO Metro. It was fun in the canyons here in L.A./ Ventura. 0 to 60 in under an hour!
https://www.ebay.com/itm/11519063749...4AAOSwL2hh4PVT
Old 04-06-2022, 01:56 AM   #6
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I have an Ultra Racing strut bar for a 91-99 Tercel/Paseo in my shed that is unopened but other than that I have no experience with them.
They seem to be fairly decent for one that is non-adjustable. I recommend the Tanabe one, you can adjust it.
2014 NCP131 5 Speed
Old 04-06-2022, 05:04 AM   #7
Calrenman
What does the adjustment do? Camber? Or just stiffen the ride?
Is the tanabe four bolts or two?
Do you have a part # or link handy?
I am new to the mods on this car. My car has been in a fender bender so adjustment may be a good call. Car tracks well. I cannot wait to put the sway bar on. The freeway is wobbly in the wind.
Thanks for the heads up.
Old 04-07-2022, 01:38 AM   #8
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Tanabe part number should be: NST45.
I got mine from RHDJapan.
This link should help you:
https://www.yarisworld.com/forums/showthread.php?t=2285
2014 NCP131 5 Speed
Old 04-07-2022, 08:34 AM   #9
Calrenman
Thank you Mitch.
Old 04-15-2022, 08:22 AM   #10
Calrenman
Did you install the bar yet?
Hello Mitch. Did you install the bar yet?
Is there a difference?
Old 04-15-2022, 11:20 AM   #11
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
No I ran out of time and didn't get around to installing the strut bar. Its on the list lol.
Planning a wedding eats up alot of time.
On the other hand, my exhaust came in from Japan so I get to install that too at some point
2014 NCP131 5 Speed
Old 04-15-2022, 08:29 PM   #12
Calrenman
You are having a party with that lil car.
did you get a "cat back" exhaust? Good luck with the wedding.
Old 04-16-2022, 07:56 PM   #13
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Yes. I got a Fujitsubo Authorize RM from Japan.
2014 NCP131 5 Speed
Old 04-21-2022, 09:37 PM   #14
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Here is the strut bar, fits like a glove. Mounting the brackets is a pain, there isn't enough clearance between the bolt and strut assembly for a socket/extension so it requires alot of patience but other than that it fit perfectly. Might be easier if you remove the wiper cowl but I did not.
2014 NCP131 5 Speed
Old 04-27-2022, 07:44 AM   #15
Calrenman
That looks great. Did it improve your handling?
It looks nice. A whole lot of Quarter turns... sucky! I will probably drop the strut. The 2015s had a recall for the strut bearings. So I will check them. Your car looks good!
Did you "tune" the front end or just put the bar in snug?
Old 04-27-2022, 01:38 PM   #16
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
You're supposed to snug up the bar while the front wheels are still off the ground so thats what I did. IMO its more of a show piece than an "upgrade" for normal driving, it seems to help with body roll when you're cornering hard though, especially coupled with the TRD rear sway bar.
2014 NCP131 5 Speed
Old 04-28-2022, 08:12 AM   #17
Calrenman
Thanks for the feedback. I think I may do this one too!
I like the look of it. I do ride hard in the canyons here in So. Cal so I might get some bang for the buck!
Old 06-03-2023, 07:14 AM   #18
Calrenman
I installed the sway bar and some rubber spring spacers that firmed the ride up and it tracks completely "true" now.
The slop in the rear axle/ trailing arm is gone! TRD sway bar is the way to go!
I also installed a trailer hitch for a bike rack that seemed to stiffen it up too.
I may have made contact with a Japanese Manufacturer of frame and body braces for test fitting some braces on the 2015 Yaris 3rd gen with an automatic. It may help get parts lists "UPDATED" and expanded. I will go to their shop at the end of the month. I will figure how to get pictures and video up to share results.
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 12:34 PM
WTB: Stock exhaust back part thing hasher22 Australia 6 04-23-2010 06:53 AM
NEED HELP - Yaris suspension part Trish General Yaris / Vitz Discussion 10 11-07-2009 01:44 PM
Back hurt? yarswiss Off-topic / Other Cars / Everything else Discussions 10 11-14-2008 04:39 PM
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 09:04 PM
