Old 05-22-2022, 02:44 PM   #1
ryanquad
Drives: 05 echo sedan turbo
Question Sheared clutch into two pieces?
So the input bearing went bad in my 2004 echo 5 speed. We had a 6 speed out of a Celica GTS lying in the shed, Installed that as an upgrade. about 10 minutes into test drive im shifting into 3rd on a on ramp at 6500 suddenly no gears. got it home and took it all apart and I had sheared the clutch friction material off the center of the clutch. I have never heard of this happening, should I stay with a stock clutch to reduce driveline shock or should I upgrade to a stronger clutch?
ryanquad is offline   Reply With Quote
clutch
New clutch, car is abysmal to drive tamrat DIY / Maintenance / Service 4 03-10-2020 04:39 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
