Old 07-04-2022, 03:01 AM   #1
TerryAdams
Angry Clicky Brake Pedal
I noticed recently, when braking at low speeds, when I apply the brake lightly, I hear and feel a slight clicking sound ( only once )
Pads, discs and calipers are basically brand new, no problems braking etc either.
It sounds to me that it's entirely inside the car and not outside at all.
Thanks
TerryAdams is offline   Reply With Quote
Old 07-04-2022, 12:23 PM   #2
sh0rtlife
well youve got a few options
the arm rests on a shaft, then below that is a pin and push rod(these often click on many makes n models) then at the end of the pushrod it goes into the power booster and thru the firewall..again a good click point..youve also got the brake switch itself..which if loose or going bad will click or squeek
if its inside the car stick your head under the dash and wiggle it around and finding it isnt hard
Old 07-04-2022, 12:34 PM   #3
TerryAdams
Why is it, I only hear the click when the car is moving and I brake lightly ?
If I press the brake when the car is still, no noise at all ?
Old 07-07-2022, 11:06 PM   #4
sh0rtlife
pressure from the brake booster....try it with the car running but not moving/in gear and see if it still does it
Old 07-11-2022, 12:57 PM   #5
TerryAdams
No it only does it when moving forwards.
This describes it
Brake Failure only when pressing the pedal gently paraklas General Yaris / Vitz Discussion 1 01-17-2021 11:26 AM
Soggy Brake Pedal 06YarisRS DIY / Maintenance / Service 3 07-14-2020 11:56 AM
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 06:10 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake pedal vibrates-not rotor problem rradhay DIY / Maintenance / Service 9 11-12-2010 09:10 AM
