Old 10-09-2022, 04:33 PM   #1
danyboy
Drives: 2012 yaris
2012 LE immobiliser key battery
I am wondering if the 2012 LE immobilizer type key needs a battery replacement or it just gets charged when in the ignition ? I opened it up and can't acces any battery unless I remove some insulation tape ???
danyboy is offline   Reply With Quote
Old 10-09-2022, 05:33 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Are you talking about the actual key, with the buttons you push to lock / unlock the doors?
If so yes it has a replaceable battery, CR2016 model. I have done this previously and there was no insulation tape present. Perhaps a previous owner jury-rigged it back together.
Old 10-09-2022, 06:24 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
There are two separate functions.
The immobiliser is an RFID type chip in the key. It respondes to a low power RF signal from the Transponder Key ECU. It is self powered from the RF signal.
The Remote Door Lock, if fitted uses a replaceable battery in the key grip to transmit a low power RF signal.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 10-17-2022, 11:58 AM   #4
danyboy
Drives: 2012 yaris
Door lock works from far away so I assume battery mus still be good. It's just that twice I had a hard time cranking the engine. It would crank but not start. Would it have anything to do with my cell phone being just met to the key and interfering with the safety key signal ?
Battery Relocation DIY tmontague Performance Modifications 7 03-23-2019 08:11 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Replacing the battery in the key jambo101 DIY / Maintenance / Service 5 01-20-2014 07:43 PM
Smart key entry - battery problems. red-demon85 DIY / Maintenance / Service 5 10-24-2013 05:28 AM
