Old 10-26-2022, 01:26 AM   #1
yaris2014toyota
Drives: Yaris 2014 2-Door LE
what is this part called? (2014 Yaris LE 2-door, plastic shield protecting belt)
2014 Yaris LE 2-door hatchback
Behind the Front Passenger Wheel there's a plastic shield that seems to be protecting a belt of some sort (possibly from dirt, etc.).
What are they called please?
  • the plastic shield (where the red arrow is pointing)
  • the belt (behind the plastic shield)
Reason I need to know: it's broken, and I need to reorder it and install it.
My guess: Thoughts?
yaris2014toyota is offline   Reply With Quote
Old 10-26-2022, 06:05 AM   #2
stidnam
Drives: Starlet
The part number you have looks correct. The picture does not look the same as other Toyota manuals, but the part number seems to match. It's also known as COVER, ENGINE UNDER, RH.
There was a different part number for 04/2014 onward for 2014 models. FYI. If you go to the parent image in your link you'll see another part called COVER, ENGINE UNDER, RIGHT with part # 51441-52330. That's the 04/2014 on part number.
I dare say the belt you're talking about is the V belt that runs the AC, water pump and alternator.
stidnam is offline   Reply With Quote
Old 10-28-2022, 01:18 AM   #3
yaris2014toyota
Originally Posted by stidnam View Post
The part ...
Thank you.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 01:25 PM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
