Old 11-09-2022, 03:39 PM   #1
surfajl77
Drives: 2009 Yaris S
Coil #3 Failed - Replace All or Replace One?
Note: 2009 Yaris is currently at 408K.
After my last episode on 10/21 where my alternator failed and left me stranded until a tow arrived 4.5 hours later, I was faced with yet another issue last night that left me in a similar situation.
On the way home from work, the engine started jerking and misfiring, so I immediately put on the hazards and was able to get off of the road and pull into a a nearby Starbucks. I had this happen to me a couple of years ago, which ended up being a failure of coil #2 - so I suspected a similar diagnosis. I requested to be towed to the Firestone near my house.
They called me and confirmed that it was indeed a coil failure, this time #3. However, unlike the last time this happened, back when my car was in the high 200s, they are now recommending that all four coils be replaced due to a risk of the others also failing.
Am I being ripped off? I mean, the amount of time between this coil failing and the previous coil failing is like....four years.
surfajl77 is offline   Reply With Quote
Old 11-09-2022, 05:09 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Coils are cheap, may as well replace all 4.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 11-10-2022, 02:23 AM   #3
IndestructibleYaris
replace 1, parts are cheap but your time isn't, and they don't all fail at once, never
IndestructibleYaris is offline   Reply With Quote
Old 11-10-2022, 02:44 AM   #4
komichal
I agree, but it seems to me that it makes actually better sense to replace all at once as it takes just a few more minutes once you are digged under the hood - then you know that you have it all sorted out and it will not fail in the least convenient time (freezing winter outside, summer vacation somewhere, desperate need to drive a relative with broken ankle to a hospital...) to spoil your situation.
Old 11-10-2022, 02:55 AM   #5
komichal
On a related note - can the coil actually get worn-out to a fact that it impacts the engine performance but does not produce an error code?
My 2007 64kW engine with 205000 km (original coils) is running realiably but it is just not as "live" as it used to be. Compression is ok. New iridium plugs helped a bit but the feeling is still a lot worse comparing to another similar Yaris I recently drove (same engine). Regularly changing fluids, filters...
Old 11-10-2022, 06:42 AM   #6
bronsin
bronsin's Avatar
Next time you get a P00123 or four don’t bring it to the dealer just swap the coils around to find the bad one do it yourself.
Old 11-10-2022, 08:00 AM   #7
ex-x-fire
Yep, a code reader and a spare coil is one thing I keep in the car.
Old 11-10-2022, 05:32 PM   #8
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Its literally a 5 minute job to replace all 4 on a 1NZ-FE lol
2014 NCP131 5 Speed
Old 11-12-2022, 01:40 AM   #9
remcafee
i like using oem coils, aftermarket ones dont have good contact on the bottom boots that grip the spark plug, just buy 1 at a time, and buy OEM coils
ABS sensor replace without hub zrwon DIY / Maintenance / Service 9 10-12-2018 07:06 AM
Should I replace the motor mounts? BennyLava General Yaris / Vitz Discussion 5 11-06-2017 09:32 AM
2008 Yaris - replace key ignition with keyless (push button) start jefflunt In Car Entertainment + Electronics (audio / video / alarm) 0 11-20-2016 06:28 PM
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 06:57 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
