Old 11-14-2022, 11:58 AM   #1
Ecefour
Drives: 2007 Yaris Hatch
Front strut mounts replacement: OEM or Aftermarket?
My Yairs is nearing 140k miles and it's time to replace the struts and rear shocks. I bought TRD shocks, TRD springs, bushings, strut mounting plates, bearings and most of the other required hardware from Toyota. The last thing I need to buy before I complete the job is front strut mounts. KYB strut mounts are $39 at my local auto parts store or $98 from my local Toyota dealer.
I think deciding to go down the aftermarket or OEM parts route typically just comes down to personal preference, but figured I'd ask anyways. Personally, I'm leaning towards OEM since I drive over 35k miles a year and I want maximum reliability and cornering performance. I can’t have my car out of commission long and I don’t want to touch the suspension again anytime soon, but of course paying over double is insulting.
Anyways I know I’m over thinking this, but what are your thoughts?
Ecefour is offline   Reply With Quote
Old 11-16-2022, 05:18 PM   #2
remcafee
you have done a great job with keeping the suspension nice and factory woth trd parts, might as well do it 100% not 90%, get the oem mounts
Old 12-16-2022, 11:35 PM   #3
Compeer
Drives: NCP90 TRD Yaris Manual
The OEM shocks are KYB's. theres no difference beteween toyota oem and the kyb.
Compeer is offline   Reply With Quote
Old 12-17-2022, 01:15 PM   #4
sh0rtlife
that explains alot as to why they work as well as they do
Old 12-17-2022, 03:00 PM   #5
Compeer
Yeah KYB makes just about all the japanese car companies OEM shocks and a bunch for other car companies from else where.
I will not buy Munroe we had so many come back failed leaking in warranty period that I do not trust anything they make, we always recomended KYB over munroe even tho they cost more.
Old 12-18-2022, 01:56 AM   #6
sh0rtlife
TBH kyb is the bottom of the barrel for me..its what ill grab is i cant afford better, with "trucks" being the exception..some of them gabrials work well
i tend to lean heavy on koni and bilstien
Old 12-24-2022, 03:40 AM   #7
remcafee
false, the kybs are far different than the oems, kyb makes them for toyota with their standards and specs
Old 12-26-2022, 03:57 AM   #8
Compeer
As a former KYB agent, I can't disagree with that more. They are ether the exact same spec as OEM's or slightly uprated as the technology has improved since the original shock was made.
Back in the 90's for a lot of the random JDM models imported to NZ the only way to get replacements was with the KYB serial number stamped on the OEM kyb which I would then get in the exact same serial number stamped shock Direct from KYB to replace them.
Old 12-28-2022, 02:25 PM   #9
remcafee
must be a european market thing then, US spec toyota shocks compared to kybs brand are completely different, especially when it comes to trucks like the tacoma and tundra
Old 12-28-2022, 04:01 PM   #10
sh0rtlife
with trucks i expect that..as they can get away with a broader interchange as well as longer(lifted) shorter(lowered) and then the fact that 1 shock may fit multiple brands and models across a decades worth of them..where cars are mostly made to a specific model...
Old 12-31-2022, 10:21 PM   #11
Billiam
Drives: '10 White Yaris 4D LB
3 years ago I replaced the struts and shocks with the black KYBs and also bought KYB strut bearings. The bearing were absolute junk.....so much so that I just reused the OEMs. Despite having 150k miles on them they were much more solid feeling than the KYB turds
If you want to enjoy your car, stay off of the internet.
Old 01-02-2023, 04:21 AM   #12
Compeer
Can't say Ive ever used KYB bushings just the shocks. I always put Nolathane bushings in cars I owned in the past.
ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right Chwbcca DIY / Maintenance / Service 5 09-15-2021 08:16 AM
MOT advisory for Macpherson Strut Mounts JohnGYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 09-04-2020 05:08 AM
OEM vs Aftermarket Water Pump? antone DIY / Maintenance / Service 0 10-23-2012 12:25 PM
WTB OEM Vitz front badge devinlamothe Willing to Buy by private party 0 03-31-2012 07:41 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 06:53 PM
