Old 11-17-2022, 04:37 PM   #1
ltwargssf
Drives: yaris
Lets see those Warm air intakes
Winter is coming, just finished putting my warm air intake, post your setups here!
ltwargssf is offline   Reply With Quote
Old 11-18-2022, 10:38 PM   #2
remcafee
i assume youre being sarcastic about the warm air intake for winter?
Old 11-19-2022, 08:52 AM   #3
ltwargssf
Drives: yaris
Haha, no I am not, they do work. That's how I keep my yaris at 45mpg+ in winter otherwise it goes well below the 40s and takes forever to warm up.
Old 12-05-2022, 07:22 PM   #4
ex-x-fire
https://yarisworld.com/forums/showthread.php?t=59283
Here's my set up from a few years ago. I think it works pretty well, I see intake temps between 75-90*F. I wouldn't be afraid to drive my Yaris on a hot summer day with those temps so why not in the winter.
Old 12-11-2022, 04:48 PM   #5
ltwargssf
Drives: yaris
Nice, I had a similar setup to yours with just the pipe but on really cold days, it would struggle to maintain 70F IATs. With the insulating materials, I can easily keep it in the 90-100 range but in traffic, it can go as high as 120-130F which is like a very hot summer day so I am not worried other it and the lack of power. My front grills are also completely blocked off all year round other than the small part on the bottom where the radiator gets its air which has been more than enough air from our little 1.5s. Those IAT numbers were in 5-10F weather.
Old 12-11-2022, 06:57 PM   #6
ex-x-fire
I'm surprised they don't make warm air intakes from the factory, with computer controlled solenoids they would open and close quickly.
Old 12-11-2022, 08:42 PM   #7
ltwargssf
Drives: yaris
The first or second gen prius has the airbox right next to the hot coolant reservoir, that is the closest attempt I've seen other than modern cars getting shutter flaps in the grills to restrict air flow on warm up.
Old 12-11-2022, 08:47 PM   #8
ltwargssf
Drives: yaris
This is my extreme temperature grill cover when the temps go below -30
Old 06-07-2023, 02:08 AM   #9
IndestructibleYaris
Instead of doing a warm air intake, do a grille/rad block off. That way, the engine stays warm as well, and the intake always gets warm air with a hot engine.
IndestructibleYaris is offline   Reply With Quote
Old 12-27-2023, 02:36 AM   #10
twidaya
Drives: Man
Send a message via AIM to twidaya Send a message via Yahoo to twidaya
ltwargssf
Nice setup! How much improvement have you noticed in fuel efficiency with your warm air intake during winter conditions?
ex-x-fire
Do you experience any drawbacks or challenges with your warm air intake setup during the winter months?
IndestructibleYaris
Could you share more details about your grille/rad block off setup, and how it impacts the engine's performance and efficiency in cold weather?
twidaya is offline   Reply With Quote
Old 01-06-2024, 06:57 PM   #11
ex-x-fire
Only drawback is the engine seems a little sluggish. That tells me it's getting plenty of warm air.
