Old 11-22-2022, 05:02 PM   #1
mik36
Drives: VERSO S
Carb cleaner via pcv valve engine running
Hi All
Hope all well
I have 1.33 1Nrfe engine I sprayed carb cleaner via pcv valve and rev up engine it came out as white smoke a bit after that car was running fine
Then after sometime return to low power feel as before
Do I have a vaccum leak torque measured 10.6 LTFT _5 stft
Do I need to clean throttle body
I have cleaned the injectors
Many thanks
Mike
Can post the torque log if that helps
mik36 is offline   Reply With Quote
For those curious about the 1.0 1KR-FE engine dj92 General Yaris / Vitz Discussion 0 09-29-2018 06:33 PM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 12:34 PM
