Old 12-07-2022, 06:52 PM   #1
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
KKT Compact 32 Piggyback ECU for 500$
TESTED WORKING AS OF 12/31/2022 USING 2001 TOYOTA ECHO ECU
Will be installed in a 2001 Toyota Echo A/T
TLDR: Got a piggyback ecu from Malaysia for 490$ this is just a write up on how to install and first start.
Hello Hopefully this is some good news about inexpensive tuning for everyone.
I have got my hands on a piggy back ECU named KKT Compact 32 which I paid for after all shipping and transfer fees was 490$.
These are pretty well known ECUs in Malaysia. That's the only bad part is there is no info on them in the states.
Everything that came with the ECU was:
  • KKT Compact 32 (ECU)
  • 4ft Wire harness
  • USB to Tune ECU
  • PDF of User Guide/Wiring Diagram
  • Tuning Software
I will add a write up on how to get ur hands on one of these once I know it works on these cars. Seems a little sketchy but PM me if you need proof.
In the next couple of days I will hopefully have a first start just waiting on ECU Connecter to make a Plug&Play Harness
I will provide a list of stuff needed to get one of these working
Pics of The ECU and Harness that came with:
Cletus Garfunkle is offline   Reply With Quote
Old 12-07-2022, 06:58 PM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
Cool, I have been looking at standalone ecu's. Does this allow for vvti control?
Compeer is offline   Reply With Quote
Old 12-07-2022, 07:19 PM   #3
Cletus Garfunkle
Average KKT User
Drives: 2001 Echo
No VVTI Control sadly just fuel and ignition.
They have there own standalone which can. I believe it would be 100$ more.
It is called the KKT Fist V2
so after all fees shipping and so on would come around to 550$ estimated.
Ill add his email once I get confirmation I can.
Old 12-08-2022, 03:28 AM   #4
sh0rtlife
i bet its alot like the gotech's ive been using on alfas
Old 12-12-2022, 10:40 PM   #5
Cletus Garfunkle
Average KKT User
Drives: 2001 Echo
Little update I made a quick Plug & Play harness and IT WORKED!
I definitely need some time in the software because first start was rich.
It ran for about 6 seconds then died from being too rich.
I will make an update to the post once it isn't 10pm and I can see what I am doing.
Ill make a simple wiring diagram to which wires need cut/spliced into and how to make a Plug & Play harness for it :). Ill cya soon
Old 12-13-2022, 07:19 AM   #6
Neinris
Can it adjust the rev limit?
Old 12-24-2022, 03:55 PM   #7
Cletus Garfunkle
Average KKT User
Drives: 2001 Echo
It looks like it can change the limiter I've watched some videos online and it seems it works.
Sorry for taking along time to update it is -3 degrees Fahrenheit in the northeast where I am located and its hard to find a time to work on the car when so cold.
Thank you to everyone who is patiently waiting on this. Next 40 degree day I will update more.
Old 12-28-2022, 11:34 AM   #8
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Cool to see someone outside Malaysia use these.
But the price after shipping and taxes isn't that competitive if you ask me there are better options out there especially if the standalone would only be 100 more.
But definitely keep us posted!
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 12-31-2022, 05:13 PM   #9
Cletus Garfunkle
Average KKT User
Drives: 2001 Echo
Quick update the problem was my bad I crossed a ground an a injector which made it stick open. The car runs pretty much perfect with all the stock settings from factory. No check engine lights no codes being thrown and MAF sensor is working perfectly with this piggyback. I will upload a video by the end of the day. :)
Old 03-12-2023, 01:42 AM   #10
Cletus Garfunkle
Average KKT User
Drives: 2001 Echo
Hello everyone AN UPDATE I have a video from 2 months ago from when I installed it first it is very easy for live tuning the fuel and ignition with some cool features like 2step/launch control.
I will be doing more updates soon once I get time.
Sorry its taken 2 months for the videos/proof I've been busy with work and doing some research on building a engine with some beefy rods and pistons for under 500$ Hopefully.
I am currently in the process of building the engine I have it torn down and getting measurements for the machine shop.
In next couple of week should have a pretty neat engine build thread popping up soon.
Video of the piggyback and tuning software running the car!
Last edited by Cletus Garfunkle; 03-12-2023 at 01:43 AM. Reason: Making Easier to read
Old 08-20-2025, 06:20 AM   #11
Fadz
Hi guys,
I already have the KKT Compact ECU installed, but unfortunately I don’t have the tuning software/installer.
Could anyone please share the download link or provide the installer (for KKT Compact 32 / F301)?
Really appreciate the help. Thanks in advance!
Fadz is offline   Reply With Quote
cheap, ecu, piggyback, tune, tuner
Piggyback ECU upgrade rabbito Performance Modifications 18 03-10-2022 12:51 AM
MWR AEM EMS 4 P&P ECU tmontague Performance Modifications 3 02-09-2020 08:07 AM
ECU Extension Harness (1st Gen Echo/Vitz) ITA Performance Modifications 4 08-24-2018 03:09 PM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
