Old 01-07-2023, 04:03 PM   #1
ethanjleighton
Drives: 2007 1.3vvti Yaris
Anti sway bar
Can anyone tell me if a rear anti sway bar is worth it on a 2007 1.3vvti? If so does anyone know where to get one that fits
ethanjleighton is offline   Reply With Quote
Old 01-07-2023, 04:55 PM   #2
ltwargssf
Drives: yaris
Yes its worth it, you will feel a difference. You will need to get 4x 10.5 Graded bolts if they don't come with the sway bar. Any shop will be able to install it, it's a very simple install with just lining it up and securing it with 4 bolts.
ltwargssf is offline   Reply With Quote
Old 01-07-2023, 05:01 PM   #3
sh0rtlife
it really depends on a few factors
how hard do you drive?
do you like to carve corners and maintain speed or do you slow down?
what size tire are you running?
all said i think its going to be great improvement, HOWEVER unless your driving hard enough on grippy tires to FEEL the rear of the body lift and start rolling on the corners your just adding weight
i still dont have one.,,but last summer after the brake work and the swap to grippier tires ive found corners where i can FEEL the rear flex and lift....and i see 3 that can be ordered up
toss 100-200lbs in the back seat, go for a drive in the twisties, remove the weight and go do it again and if you cant feel the change in how the rear acts you dont need a sway bar..if you can feel it..you need one
Old 01-08-2023, 03:35 AM   #4
ethanjleighton
I’m running 15 inch tires(I’m not sure what they exactly have but it’s the stock size). I would say I drive pretty hard most of the time but I’ve been looking for some easy mods that don’t require a lot of time to fit. But I’m kind of inexperienced although I’m training to be an agricultural engineer so I currently have a basic knowledge of how to fit things but I know how things work.
Old 01-07-2023, 06:02 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Yes its worth it, it makes a positive difference in every way regardless on how you drive. It should have been standard equipment on these cars.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 01-08-2023, 06:58 PM   #6
sh0rtlife
if you drive a lil hard then yes by all means toss one on, i think the 2 most readily availible are "whiteline" and TRD
Old 02-16-2023, 07:57 PM   #7
RedRide
RedRide's Avatar
You will definitely feel the difference. I installed one on my '09.
It really transforms the handling for the better
You would not think it would with the non independent solid rear axle but, it does.
BTW, there area few different vendors that sell their version of this sway bar.
Just get one that is made to fit your year Yaris
Once you get one, it is a fairly easy install
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
rear anti sway bar = better mileage? Lewis Fuel Economy Forum 42 12-04-2009 10:42 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 01:22 AM
