Old 01-18-2023, 12:23 AM   #1
Bibsta
Drives: 08 YRS 1.5L Man
Swapping 2NZ-FE(ex Auto) into 1NZ-FE (man)
Hi All
Done alot of searching and not found many definitive answers on this subject.
Best/most relevant posts appear to be those below from 2009 and 2017 respectively.
I have a manual 06 Yarris 1NZ-FE and am looking to swap in a younger mileage 2NZ-FE from another 06 donor car equipped with an auto trans.
Does anyone know if there are any parts specific to the donor vehicle 2NZ-FE that will be needed to go on my 1NZ-FE manual?
Only the engine is being changed 2NZ-FE --> 1NZ-FE. The posts below appear to suggest the only change required is the long block/motor with no other physical/electrical changes.
Does anyone have the experience to confirm this?
See relevant posts below. Apologies if this subject has been covered elsewhere and I have missed it when searching.
https://www.yarisworld.com/forums/sh...=1nz-fe+2nz-fe
https://www.yarisworld.com/forums/sh...=1nz-fe+2nz-fe.
Thanks, Bibsta.
Bibsta is offline   Reply With Quote
1nz-fe, 2nz-fe, conversion, swap, transplant
Auto or Man Transmission? bad General Yaris / Vitz Discussion 3 03-01-2022 04:58 PM
Yaris MPG falls to 31 (auto) 32 (man) under new guidelines deebrown General Yaris / Vitz Discussion 30 06-26-2007 04:18 PM
