Old 02-02-2023, 04:11 PM   #1
A_scrace
Drives: 2004 toyota yaris t3 3 door
P0171 fault code
Just had a p0171 fault code show couple days ago.
Anybody got any ideas what it might be.
A_scrace is offline   Reply With Quote
Old 02-02-2023, 04:29 PM   #2
Your fuel mix is running lean, too much air. Top thing to look at in any google result is the MAF sensor needing to be cleaned.
Old 02-05-2023, 09:22 AM   #3
ex-x-fire
Maybe the duct between the Maf and the throttle body is torn.
Old 02-05-2023, 12:05 PM   #4
bronsin
bronsin's Avatar
How do you fix code P0171?
You can usually fix P0171 using the following steps:
Replace the fuel pump or fuel filter.
Change the fuel pressure regulator.
Replace the powertrain control module.
Change one or more injectors.
Replace one or more oxygen sensors.
Change the mass airflow sensor.
Repair vacuum leak
Old 02-05-2023, 12:05 PM   #5
bronsin
bronsin's Avatar
I’m guessing vacuum leak
Old 02-05-2023, 12:06 PM   #6
bronsin
bronsin's Avatar
code?
Is P0171 serious?
Issue Severity: MODERATE– Extended driving with this code can cause internal engine damage. Repair Urgency: Get this code fixed as soon as possible to avoid damage to spark plugs, pistons, and catalytic converters. Diagnosis: It is important to complete the entire diagnostic process when diagnosing P0171.
Old 02-05-2023, 01:05 PM   #7
A_scrace
There is no duct as the air box pushes on the throttle body.
Old 02-05-2023, 01:06 PM   #8
A_scrace
Repair vacuum leak
There is no fuel filter on my model also have replaced all 4 injectors and maf sensor along with both oxygen sensors.
Old 02-05-2023, 04:49 PM   #9
bronsin
bronsin's Avatar
No fuel filter? Are you sure?
I’m guessing you have a vacuum leak. Have you consulted Scotty on YouTube? He describes a procedure for locating vacuum leaks. I think it involves spraying something like WD-40 on it around the vacuum lines of the engine and listening for RPM increase. If it increases when you spray It someplace there’s your leak
Old 02-06-2023, 05:59 AM   #10
BLH
Drives: 2007 Yaris Sedan
The filter maybe part of the fuel assembly. In the top of the fuel tank.
My 2007 has the filter inside the fuel pickup assembly on the top of the fuel tank.
Old 02-06-2023, 10:34 AM   #11
bronsin
bronsin's Avatar
Sometimes the fuel filter is integral to the fuel pump
Getting a P0171 code even after taking it to the shop Chip Whitley DIY / Maintenance / Service 3 01-30-2021 09:24 AM
SRS B1653 fault code CB900F2 DIY / Maintenance / Service 3 11-14-2018 08:33 AM
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
Yaris CDX 1999 P0171 error code Davax DIY / Maintenance / Service 2 08-18-2010 07:14 PM
error code P0171 bronsin DIY / Maintenance / Service 17 03-12-2010 06:22 PM
