Old 03-07-2023, 07:29 PM   #1
Ilovemyyaris
Ilovemyyaris's Avatar
Drives: Blue 5 door hatchback Yaris
Lightbulb How much MPG loss would putting a 1 or 2 inch lift kit on the yaris be?
I know it will reduce the MPG some but by how much?
Also, will a 2 inch lift kit make it top heavy enough to worry about rolling/flipping it?
Ilovemyyaris is offline   Reply With Quote
Old 03-08-2023, 06:33 PM   #2
sh0rtlife
lift vs roll will ALWAYS come down to TIRES, spring rates, wheel offsets shocks and swaybars, as well as driving style....so long as you go a lil wider and a lil stiffer it will be exactly the same
as for MPG thats going to be more effected by the rolling stock than the lift..sure youll lose atleast 1 to more air under the car but i doubt youd lose 2
Old 03-09-2023, 08:52 AM   #3
ltwargssf
Drives: yaris
At least 1mpg. I gained a few mpgs dropping mine but I also have full cover undertrays. I would look into at least putting a front skid plate/cover to smooth things out. You can cover the whole thing and it will probably be better mpg than stock with the lift. It really helps highway stability too.
ltwargssf is offline   Reply With Quote
Old 03-09-2023, 11:29 AM   #4
Neinris
You might gain some of it back with bigger tires. You'd lose acceleration, but will gain better top speed. Meaning less rotation per mile.
Brand New 2010 Yaris 5 door automatic, <200 miles, MPG 127.0.0.1 Fuel Economy Forum 12 09-07-2019 09:11 PM
2013 Yaris Really bad MPG??? Pmansbridge Fuel Economy Forum 8 03-05-2018 11:48 AM
Loss of MPG RETRO Fuel Economy Forum 7 02-05-2015 06:50 PM
