Old 03-24-2023, 10:15 AM   #1
Mightymoo
Drives: Yaris Mk2
Brake caliper rewind tool for rear brake piston
Looking for a Brake Caliper Rewind Tool that fits rear brakes on Yaris MK 2.
Any tips on dimensions of the piston or cheap tools that fits?
Thanks!
Mightymoo is offline   Reply With Quote
Old 03-24-2023, 10:34 AM   #2
Neinris
Thanks!
Needle nose pliers...
Old 03-24-2023, 02:41 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
C-clamp and a piece of wood
Old 03-24-2023, 02:55 PM   #4
sh0rtlife
i was under the impression these cant just be "clamped" as they have a "threadout" attached to the Ebrake mech and you have to thread it back in for a full reset
Old 03-24-2023, 03:05 PM   #5
That is correct. No simple c-clamp compression with those puppies.
Tools are cheap enough to buy. Better yet, maybe some of your automotive supply stores have a loan-a-tool program. Needle nose pliers will work but may involve some colourful language in your part.
Old 03-25-2023, 02:08 AM   #6
NYC-SE
NYC-SE's Avatar
My apologies. I've never actually done the brakes on my Yaris. The C-clamp method has worked on everything else I've worked on so it was my default option. Please ignore my advice.
Old 03-25-2023, 01:19 PM   #7
remcafee
sst and sst only! needle nose pliers are not a good idea, you will scratch up the surface of the piston
Old 03-25-2023, 05:56 PM   #8
ex-x-fire
Google brake cube tool.
Old 05-07-2023, 02:52 AM   #9
Mightymoo
Drives: Yaris Mk2
Thanks for the feedback
Got the cube on eBay.
Will update on the success.
Old 05-07-2023, 02:01 PM   #10
sh0rtlife
having just done the xb2 a few weeks back i can tell you 2 things, you need to push a a lil as you turn it and you need to verify the direction of rotation...not all of them are clockwise
with that said i had to turn one both directions to "free" it up so it would finnaly actualy thread in, and found that too much pressure and it wont, too little and it will just spin
in the end tho i didnt need a tool..tho the xb ones have nice grab notches on the edge of the piston so you can pretty much do it by hand
Old 05-08-2023, 05:59 AM   #11
Mightymoo
Drives: Yaris Mk2
I did put the order on hold due to a question:
I have a manual old fashioned hand brake (no electronic parking brake or park button).
Do I need a rewind tool then, or is that just for the electric motor in the e-brake?
Old 05-08-2023, 07:10 AM   #12
ex-x-fire
The electric parking brake systems have to be put in service mode with a scanner then the piston usually get compressed straight in. Use the cube to wind in the older style calipers.
Old 05-08-2023, 11:07 AM   #13
sh0rtlife
if youve got a hand brake youll like having the tool, not everyone needs it, but when you do youll wish you had it
MOVED - Brake caliper rewind tool for rear brake piston Mightymoo General Yaris / Vitz Discussion 0 03-24-2023 07:24 AM
"Thunk" sound after caliper and brake pad replacement Hamster DIY / Maintenance / Service 3 08-22-2020 10:34 PM
New brake caliper installed 06YarisRS DIY / Maintenance / Service 2 08-21-2020 10:35 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
