Old 03-31-2023, 07:54 PM   #1
bronsin
bronsin's Avatar
My 200,000 mile drain plug washer is gone!
I just changed my wife 18-year-old Camry with 200,000 miles on it just change the oil. My son did the last oil change last year when I was in the hospital. He threw the drain plug washer out! He changed it with an official Toyota washer the kind that’s aluminum with blue coating on both sides.
I’m going to miss that washer.
Old 03-31-2023, 10:27 PM   #2
bronsin
bronsin's Avatar
Here’s the drain plug with the new genuine Toyota coded on both sides with blue stuff gasket. I replace it with a quick drain plug. You don’t have to use a wrench on.
File Type: jpg A05FECF4-1A75-4893-951A-DAF42E93606B.jpg (192.3 KB, 60 views)
Old 04-01-2023, 12:33 AM   #3
sh0rtlife
i...i just cant bring myself to trust those "quick" drain plugs....
Old 04-01-2023, 02:20 AM   #4
bronsin
bronsin's Avatar
I was worried it might hang too low and be hit by something. But I don’t think that’s the case. The one thing I see about it is the hole for the oil to run out is maybe 1/3 the size of the hole the original drain plug fits in. It’s going to take a long time for the oil drain.
Old 04-04-2023, 05:04 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Oh no the horror.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 04-05-2023, 11:16 AM   #6
sh0rtlife
i know guys that run em on bikes and stuff too..and the idea will NEVER sit right with me..as its the life blood of an engine...a rock flying up just right etc is always possible..hell big rig rubber chunks
almost 130k miles and the windshiled took a bunch of rock chips yesterday while out and cracked all the way across this morning while my wife was on a run to the coast....so this glass joins your original washer
Old 04-05-2023, 11:19 AM   #7
bronsin
bronsin's Avatar
On my trips out west cracked windshield abound ED!
Old 09-21-2024, 03:58 PM   #8
robkay
Drives: Hatch
Hey, speaking of drain plugs. Do you guys torque your drain plug?
I try to torque everything. I started out torquing it to spec, 28 ft lbs, but after about 10 years it became pretty hard to crack loose, so I started torquing at 20 ft lbs. which was good.
I just changed my oil yesterday and the plug was a bit hard to crack loose. I am a little nervous about going lower than 20 ft lbs.
Any thoughts?
robkay is offline   Reply With Quote
crush washer on drain plug? 2007yariz DIY / Maintenance / Service 17 10-06-2024 02:10 PM
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
Review: Magneticdrainplug.com's magnetic drain plug schleppy DIY / Maintenance / Service 13 04-21-2009 12:04 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
