#1 |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
A very common part to break for Yaris Gen 3
This AC Compressor Clutch Plate looks crappy by design, will eventually fail in no time. Some may fail in less than 3 years, other may last more than 5 years and all of them will suffer the same fate.
I can definitely say this is very common issue to all gen 3 and is just a waiting time bomb. Mine detached at 177k km. I replaced the clutch plate from a denso donor and did a little sanding on the mating surfaces and installed the shims needed with some tight clearance. Now it is back into action. Would want to buy a new magnetic clutch assembly next time that includes the pulley and coil |
Noted.
Synthetic Oil: Its All In Your Head |
#3 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 5dr canadian import Join Date: Dec 2016
thats terifying with the speed they are spinning as well as being under tension....the fact they dont launch and do other damage is actualy kinda supriseing
but it also begs the question...how many of these fail due to an over tight belt |
#4 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
yup, i see it all the time, not only yarises, all cars in general
#5 |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Never had an issue with mine and its going on 10 years old
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#6 |
That's a different design than what we have here. External vs internal clutch. Our big round retaining nut cannot break, just spin off the threaded shaft. At least when their's break, there is still a nut holding the pulley on.
| DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) | CTScott | DIY / Maintenance / Service | 12 | 01-22-2022 03:09 AM |
| Gen 2 vs Gen 3 Dilemma | bigjmeister | General Yaris / Vitz Discussion | 5 | 01-03-2015 04:37 AM |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
| break line: 1,5 RS vs. 1,8 TS | Patitwelve | Performance Modifications | 2 | 10-14-2010 04:34 PM |
| 2008 OEM S model Liftback Lip kit Part numbers | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 17 | 07-26-2010 01:33 PM |
