#1 |
Yaris beginner
1NR-FE Valve Cover Gasket replacement
Hi all,
My 1NR-FE engine is leaking from the top and I'd like to replace the valve cover gasket. I have the gasket already, and I started trying to do the job but honestly the electric cable harness on top of the engine is slightly more complex to remove than I expected... If anyone could provide some help, maybe a short video, pointing to the best option/way to remove the electric cable harness just enough to make the replacement of the gasket an "easy" job, would be very much appreciated! Thank you. |
| 2006 Yaris head gasket replacement? | jzr756 | DIY / Maintenance / Service | 1 | 04-30-2022 11:13 PM |
| Valve Cover Bolt Size help. please. | 06YarisRS | DIY / Maintenance / Service | 1 | 01-02-2018 06:53 PM |
| Front Exhaust Gasket Replacement | tmontague | DIY / Maintenance / Service | 6 | 03-25-2015 11:00 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 04:30 PM |
