Old 07-28-2023, 06:07 PM   #1
RonanS5
Drives: 2010 stock yaris
Yaris Clutch Adjustment
Is it possible to adjust the clutch in a stock 2010 Yaris?
RonanS5 is offline   Reply With Quote
Old 07-28-2023, 10:10 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Nein.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 08-01-2023, 04:20 AM   #3
remcafee
you can adjust the clutch pedal free play, usually its already at the perfect adjustment, their is a spec for it if you wanna check and are bored, most likely its going to be in spec
Old 08-02-2023, 06:08 AM   #4
bronsin
bronsin's Avatar
If you aren’t happy with your clutch operation,bleed the clutch cylinder. Since the clutch is operated about 100 times more than the brakes are, it should be bled once a year.
Old 08-20-2023, 09:05 AM   #5
Compeer
Drives: NCP90 TRD Yaris Manual
Yes and unless its different the clutch feeds from the brake master cylinder and when you bleed the brakes you are supposed to do them in sequence and always finish with bleeding the clutch slave cylinder.
Mine goes all soft and bad feeling if its not bleed correctly after messing with the brakes. Bleed longest line to shortest, on our cars its going to be left rear, right rear, left front, right front, clutch slave cylinder to get all the air out correctly.
When I changed to the RS subchassis I tried to bleed as normal and it was not right until I did the full sequence in order.
Compeer is offline   Reply With Quote
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 11:42 AM
'07 Yaris Clutch replacement dinop DIY / Maintenance / Service 12 04-22-2013 05:47 AM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
