Old 08-11-2023, 11:41 AM   #1
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
'08 Hatch Striker Plate Loose (Easy Fix!)
Hey all, a little background I own an '07 3dr Hatch (AT) and just picked up an '08 3dr Hatch (MT).
On the '08 I noticed the hatch striker plate was loose. I took the interior plastic trim off and looked behind the bumper and there are no good access points to this (big enough to fit my hand in), the only access points are two oblong shapes (best described as elongated circles, but not quite). Anyway, I read a few posts regarding this subject and found everything from cutting holes in the trunk to people making special tools for the job to tac welding the striker in place.
I did not include how to take off the plastic trim because it was merely removing two (2) plastic fasteners and pulling it off.
Well I found an easy fix and I hope this helps someone in a similar situation.
Striker Plate:
Holes to Access the striker plate nuts:
Right Access Hole w/flashlight for visibility:
Left side access hole:
View through right access hole:
Offset box end wrench 14mm (Duralast brand I got from WalMart):
Offset box end wrench in right access hole over loose nut:
Woohoo! This took me about 5 minutes to complete.
TommyWasabi is offline   Reply With Quote
Old 08-11-2023, 03:05 PM   #2
No pics!
Old 08-11-2023, 05:49 PM   #3
TommyWasabi
No pics!
They were there initially. Not sure what happened. Can you see them now?
Old 08-11-2023, 06:00 PM   #4
TommyWasabi
Here are the pics in order. I added them in as attachments in case the net code dookied again.
Old 08-15-2023, 06:16 PM   #5
remcafee
those are supposed to welded nuts, seems to be common that the welds come loose
Old 08-15-2023, 06:16 PM   #6
remcafee
going to go check mine right now
Old 08-17-2023, 04:51 PM   #7
TommyWasabi
Thats right, the nuts are tac welded on the inside and the welds tend to break loose over time.
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 10:22 AM
DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) CTScott DIY / Maintenance / Service 15 12-30-2015 06:27 PM
Any EASY way to add ABS to an 07 3D hatch? Shinare Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 11-07-2011 04:57 PM
2010 Prius brake problems easy fix. best video ever! dinamix Off-topic / Other Cars / Everything else Discussions 6 03-14-2010 11:00 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
