Old 09-03-2024, 01:20 PM   #1
niklasnestori
Drives: Toyota Yaris
Yaris 1KR-FE engine problems
Hi,
I own a 2006 model year Yaris with a 1KR-FE engine. The car has approximately 200 000 km. Chain is the original one. I have done oil change every year between every 10 000 km.
Engine shakes quite a lot. I did try to clean throttle body and it didn't make any difference. After that clean up I've faced a problem that rpm of the car starts to bounce sometimes when the car is idling. For example if I rev the engine the rmp might bounce slightly and the idle itself is quite rough.
niklasnestori is offline   Reply With Quote
Old 09-15-2024, 11:10 AM   #2
bairjo
Are you getting a check engine code? If not, is it time for spark plugs or even an ignition coil? Check for a broken vacuum hose as well. Also clean the MAS....it probably needs it anyhow.
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
2009 1KR Yaris engine shuddering in 1st gear tamrat General Yaris / Vitz Discussion 5 12-10-2016 03:41 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
