Old 09-23-2024, 03:56 PM   #1
Theviking34972
Theviking34972's Avatar
Drives: yairs 2004
head light problem
Hi guys new here joined after thinking my drivers side headlight bulb had failed yesterday i bought a new bulb turns out it is more of a problem than i first thought.
i read a previous post before posting i have tried all fuses and tested with a multimeter all fine. i have tried new bulbs and tested them also with multimeter.
Connection box is full of gunk and grease so will clean tomorrow and report back but i have just noticed that the full beam works so this must mean the connection is fine ?. i am now running out of options please help. thank you
Theviking34972 is offline   Reply With Quote
Old 09-23-2024, 07:00 PM   #2
Have you tried swapping bulbs from side to side to see if a known fully functioning bulb exhibits the same behaviours in its new location?
Old 03-03-2025, 05:26 PM   #3
Theviking34972
Drives: yairs 2004
hi thank you for the reply. i haven't but will do tomorrow. how would i test the ports with a millimetre ?. as i have mentioned the high beam works fine.
Old 03-09-2025, 02:20 PM   #4
CrimsonEclipse
Drives: .
Due to design, many owners remove the boot protecting the back of the headlight assembly, since the boot deteriorates and sticks to all parts.
That is likely why the connector is coated in vasiline to protect it from moisture in stead of the boot
CrimsonEclipse is offline   Reply With Quote
Toyota Vitz Auto Climate Control Light Problem Gina87 DIY / Maintenance / Service 3 01-18-2016 05:45 AM
IN:Double Halo Rim Projector Head Lamps w/ LED Light BLACK dreamindiesel Items for Sale by private party 41 02-22-2012 04:35 PM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
In car Audio - Head Unit installed but a little problem... YoyotaTaris In Car Entertainment + Electronics (audio / video / alarm) 7 08-06-2007 12:34 PM
