Old 02-11-2025, 07:12 AM   #1
Showtyme400
Drives: 10 Yaris Hb, 02 Camry 2.4
Buying a 2010 with some issues.
Will be buying a 2010 Yaris Saturday, does have 2 issues that I am aware of. Guy claims that it needs drum brakes, however it has a loud rumble exactly like bad wheel bearings. However, when you press on the brake it almost goes to the floor before the brakes engage. I know its hard to pinpoint online just want some opinions. Car has 173k on it, would the drums be bad at this point? Like I said the guy claims that it needs drums, would drums cause a loud wheel bearing type noise while being driven? Car ran great other than that, clean no leaks no rust. Buying it for 3500, he wouldnt budge on the price. Its a black two door.
Showtyme400 is offline   Reply With Quote
Old 02-11-2025, 10:54 AM   #2
bronsin
bronsin's Avatar
If the car runs well and that’s the only problem it’s a material what it is. It’s either one or the other. By the car and fix the problem that’s my advice.
Good luck and tell us what happens!
Old 02-11-2025, 07:19 PM   #3
ex-x-fire
Sometimes just adjusting up the rear brakes improves the pedal travel. Might have a lot of dust in there causing the noise.
Old 02-12-2025, 07:29 AM   #4
Showtyme400
Thank you guys, got quoted 520 to replace the rear drums. Gonna be dropping it off Saturday so they can look it over on Monday, just dont trust myself to do the rear drums.
Old 02-21-2025, 07:32 AM   #5
Showtyme400
It was the rear passenger side wheel bearing. Actually found a new one on Facebook for 25 bucks. So I fixed it for 25 bucks, hardest part was the ABS clip, had me puzzled to take it off. Finally got it off tho.
Old 05-02-2025, 06:26 PM   #6
just1witness
Drives: 2009 Yaris Sedan
My 2010 had a drum essentially implode last summer, the repair guy opened them up and said there was nothing to them anymore. (147,000 miles sedan.)
***Edit: forgot to mention, the brake pedal went to the floor, and was all gooey.
just1witness is offline   Reply With Quote
Found : head gasket oil leak on 2 used 2010 YARIS ... Hershey DIY / Maintenance / Service 200 04-23-2013 11:22 PM
buying a new yaris ....2010 vs 2011? romram New YARIS Purchase Forum 4 07-06-2011 07:59 PM
HELP! Buying a used 2010 Sedan from a car rental company vst General Yaris / Vitz Discussion 18 04-06-2011 07:28 PM
How much did you pay for your 2010 Yaris? rytis New YARIS Purchase Forum 99 01-15-2011 06:26 PM
Does the 2010 5-door/5-speed actually exist? adrew New YARIS Purchase Forum 26 12-14-2009 06:57 PM
