Old 05-21-2025, 11:06 AM   #1
Likesavinggas
Drives: 2007 Yaris
Check Engine Light (air filter)
Hello, I own a 2007 Yaris and it's been a good car for these many years, just one repair last year to replace the water pump (bad bearing). It was still working fine when replaced (no check engine light). Recently I realized that the original engine air filter was still in place (for 18 years, ugh). So I bought a new filter and things seemed fine until the check engine light came on about a week later. This was the very first time the CE light had ever lit up. So after removing it and re-installing the filter again the CE light came on again (had to disconnect battery to deactivate the light, but it came back on again later). The error code indicated the light had something to do with the air filter system so I figured it must be the new filter?
Anyways, I put the old air filter back in place and deactivated the CE light again. If it does not light up in the next few days I'll assume the new filter is the cause. I'll return here to update soon and if the CE light does not come back on I'll go to the dealership to buy a real Toyota air filter and see what happens. Otherwise I have no complaints about my 2007 Yaris other than the old paint job looking bad now. Has anyone here had a similar air filter problem? Thanks
Likesavinggas is offline   Reply With Quote
Old 05-23-2025, 06:38 AM   #2
komichal
I cannot imagine how a new air filter can bring up CEL.
If the error comes again, type the exact error here.
Do you have a picture of this 18 years old air filter? I cannot imaginge how it looks, especially when I need to change it twice a year (living next to a lime quarry).
Anyway, I would suspect that during the filter change procedure a piece of dust may have flew off the filter and maybe hit the MAF sensor or got stuck in a throttle body. If the filter was not changed for 18 years we can assume that there was no cleaning of MAF or throttle body as well. These would be my primary points of interest.
I could also imagine some dramatic way of changing filter so that the whole airbox gets moved a bit, resulting in fake air being sucked in and "too lean" error. But lets start with cleaning up the airbox, MAF sensor and throttle body.
18 years.... omg... do you change oil, oil filter, brake fluid?
Old 05-23-2025, 09:49 AM   #3
Likesavinggas
Drives: 2007 Yaris
Thanks for replying, yes I keep up with all other aspects, oil, etc. The old filter is back in place so a pic isn't possible at this time (it was black). So far after 3 days of driving the CE light has not come back on. Will give it some more time and get back with you later.
Old 05-24-2025, 07:39 AM   #4
ex-x-fire
I'd put the new filter back in, clear the codes, and unhook the battery to start off fresh.
Old 05-24-2025, 09:35 AM   #5
Likesavinggas
Drives: 2007 Yaris
Update : Ok, after 4-5 days and ~150 miles of driving with the old filter back in place the check engine light has Not come back on. Beforehand, with the new filter in place the light came on after just 50 miles of driving (twice after deactivating the CE light). So the problem does not seem to be anything other than the new filter, at least so far anyways. I will leave the old filter in place for a while longer to see if the EC light comes back on.
Komichal, do you mind if I ask what brand of air fitler you use? Is it an original Toyota part? The one I bought via Amazon is a PHILTOP Engine Air Filter which is supposed to be for my 2007 Yaris and it does appear as an identical match to the old filter. Both filters seem to fit perfectly into the filter box and all henges and latches lock into place a-ok.
Old 05-25-2025, 11:45 PM   #6
komichal
Well as I am changing often (because of visual layer of dust on it) I tried many brands, they all worked just fine.
Denckermann, Mann, Hengst... all good. No Philtop brand here for me to check.
No matter if it cost 2 or 10 bucks, they delivered the same performance. I have never noticed a difference nor a problem with CEL came up.
Maybe if the new filter is too dense and the ECU evaluates the air path as clogged?
ex-x-fire made a good comment about total reset by unhooking the battery for a while. That should reset the ECU. If that does not help you can try to buy some cheap filter and put it in to see what happens.
Old 05-27-2025, 10:00 AM   #7
Likesavinggas
Drives: 2007 Yaris
Post
Thanks Komichal and all for your replies. As mentioned in my previous posts I have deactivated the EC light a few times while testing out both the new & old filter (again). Update : after a week running on the old filter the CE light did come back on (after ~200 miles driving). So yesterday I deactivated the light again and reinstalled the new filter. I have triple checked the installation to make certain the new filter was seated properly and all hinges and latches locked a-ok, no leaks detected visually.
The engine sounds perfectly normal with both filters, no hesitation, no stalling, nothing unusual when driving slow, fast, or accelerating, and easy to start. We'll start to drive the Yaris again today to see if/when the CE light comes back on. Seems hard to believe a new filter would restrict air intake more than the old filter, but maybe the sensor doesn't like the extra clean air now, ha.
Anyways this is my last shot at figuring out the EC light assuming it comes back on this time. I have read that if it starts to blink then the problem is getting serious. I'll attach a pic of the old filter, even sunlight does not penetrate it.
Old 05-27-2025, 02:10 PM   #8
Likesavinggas
Drives: 2007 Yaris
We drove the Yaris 40 miles today, no CE light yet with the new filter re-installed. Will update in the coming days if or if not the CE light comes back on...
Old 05-28-2025, 05:56 AM   #9
komichal
how did you deactivate the CE light? If you did so by disconnecting battery for some time then this also resets the ECU, but if you deactivated it using OBD diagnostics error reset then this does not reset the ECU and it still remembers all values it learnt so far.
So to sum it up:
1. Make sure the battery has been disconnected for a few minutes.
2. If the error comes back, read the code and post it here
Old 05-28-2025, 09:46 AM   #10
Likesavinggas
Drives: 2007 Yaris
Yes I deactivated the CE light each time by disconnecting the battery for a few minutes and also tapping the horn to fully drain any capacitors which might be still energized. I went to Advance Auto for their free CE light code reading 2 weeks ago for this diagnostic test and it indicated that the issue was with the engine air intake system (listing several possibilities and nothing specific). I have the print out in the garage but it's raining hard now and will retrieve it later to post the code when I get a chance. None of this started (EC light) until a few days after I first installed the new filter.
Old 05-28-2025, 10:07 AM   #11
I don't believe you've ever answered the question about cleaning the MAF sensor.
Old 05-28-2025, 05:07 PM   #12
Likesavinggas
Drives: 2007 Yaris
My apologies, I overlooked the MAP reference to look it up later. I'll get back to the thread in a day or two once I better understand the procedures and explain why I haven't gotten that far into it, yet.
Old 05-29-2025, 09:45 AM   #13
Likesavinggas
Drives: 2007 Yaris
Update : Ok, The reason I haven't gotten as far to check out the MAP is that I'm still in the troubleshooting stage to determine if the new air filter or its possible improper installation is the reason the CE light comes on after driving for several days. I'm no mechanic so I'm a bit reluctant to dive further into the MAP inspection but from the description of the possible problems (from the test re-out) it doesn't sound like the MAP is the reason for the EC light. The Yaris has shown no suggested possible problems when starting or running, no hesitation, no issues with acceleration, no sign of power reduction, etc. The engine runs very smoothly and normally. The MAP wiring appears well connected, good and clean and if there were a wiring/connection issue I would expect the EC light to come on immediately and not take several days and many miles to light up (although I could be wrong about that, not a mechanic as said). At this point I may just leave the new filter in place and see if/when the EC light comes back on. If it does come back on I may just ignore it for now and monitor the gas mileage to see if it drops and if the engine performance changes for the worse.
At this point digging into the MAP to inspect it might make matters worse since it's a 2007 model and I'd rather now screw up a component that appears to be working ok. I really appreciate the advice given from all posters and if anything changes in the coming weeks I'll be back with an update. In the meantime I will search for more info on my Yaris model and review videos on how to properly inspect and clean the MAP if it comes down to that. Thanks again, and if anyone knows of an instructional MAP maintenance video specifically for my 2007 2 door hatchback Yaris please do share it.
Old 05-29-2025, 03:25 PM   #14
MAF not MAP
The magic in the MAF is two tiny filament wires inside the MAF housing. These measure the rate of air flow passing by them and they can develop a coating of gunk over the years which needs to be cleaned off. There is nothing unique about a Yaris MAF to concern yourself with.
Old 06-01-2025, 03:37 PM   #15
komichal
If your profile is correct and you are from Virginia you are most probably having a Yaris with an engine that was not sold in Europe so I have no personal experience with that, however taking the MAF out should be fairly easy - two bolts out, disconnect wiring, gently pull it out while twisting a little clockwise and counterclockwise. There is no bayonet or anything. Just a big silicon o-ring that comes out with the sensor easily.
Once it is out, spray it generously with MAF sensor cleaner (do not use brake cleaner or throttle body cleaner as these can leave residues). MAF sensor does not leave any and means no harm to the electronics. You need really to spray it generously INSIDE the sensor. As WeeYari mentioned, the MAF sensor is made of two tiny wires buried deep in the sensor so you need to hit them with that spray a few times. DO NOT TRY TO BRUSH THEM.
Apart from these two wires you may also notice a little "droplet-like" bubble which I believe is a thermometer for air intake. Spray that one too.
Once it is done, let it dry - the cleaner dries quickly. Once it is dry, gently push it back in, secure with the bolts, connect wiring.
Disconnect battery once again for a minute so that the ECU forgets what it knew from the dirty MAF.
It would really help with the debugging if you can get yourself and OBD reader and get the exact error code the ECU throws. Like P0171 or something like that. These are like 6 USD per piece.
Old 06-01-2025, 03:37 PM   #16
komichal
Old 06-07-2025, 12:36 PM   #17
Likesavinggas
Drives: 2007 Yaris
Thank you all for the replies. Since my last visit to this site I've been too busy with some family issues to get back here and/or follow your good advice to clean up the MAP. In the coming days I will carefully perform the MAP cleaning with the proper cleaning solution. The CE light did eventually come back on with the new air filter re-installed so it must be the MAP. I shall return, sorry for not replying sooner but at present I do not recieve your replies in my email.
Old 06-15-2025, 09:38 AM   #18
Likesavinggas
Drives: 2007 Yaris
Ok, one last question before I perform the MAP cleaning. I ordered a can of CRC MAP Sensor Cleaner and have reviewed the instructions (also have viewed several utubes on how to do it). On the can it says "Do Not use on a vehicle with a Karman Vortex air flow sensor e.g. on some 2006 and older Toyotas" I would assume that my 2007 Yaris is ok?, but would like an expert here to confirm that my Yaris does not use a Karman Vortex air flow sensor. Thanks for your guidance on this.
Also, in a couple of those youtubes the mechanic would keep the engine running while unplugging the MAP sensor. They did this to show that if the engine stopped running then the MAP sensor was working as it should (though it still may need cleaning), but if the engine kept running then the MAP sensor was defective. Would you recommend this step?
2000 Vitz check engine light BomB191 DIY / Maintenance / Service 3 05-31-2012 09:35 AM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
Part Number(s) for '09 5-door LB engine air filter? IsLNdbOi DIY / Maintenance / Service 5 01-02-2011 01:51 PM
check engine light twice within a week of purchase?? conurebuddy General Yaris / Vitz Discussion 8 04-17-2009 10:53 AM
