Old 06-02-2025, 05:25 AM   #1
NoLifeLiam
Drives: 2012 Yaris 1.3 5MT
Knock on cold start
Hey guys.
Vehicle in question is a 2012 Yaris, 2NZ-FE, 5 speed manual with 123,000 kilometres on it.
Just went to move it and it had a definite knock for a few seconds on startup. Checked it today and I'm pretty sure the oil is at the right level.
Took a video if it idling afterwards, which sounded a bit ticky with a small knock at low RPM/idle, but otherwise normal.
Currently running 5W-30 oil in Melbourne, AU. Motor has had regular servicing and runs really nicely otherwise.
Going to check in the morning and see how it sounds.
Any thoughts/advice/comments?
Cheers.
NoLifeLiam is offline   Reply With Quote
2012, 2nz, knock, yaris
won't start after 5 days of extreme cold weather, battery fine yaris2014toyota DIY / Maintenance / Service 2 02-22-2025 05:24 PM
Yaris won't start properly/reliably lith89 DIY / Maintenance / Service 10 11-21-2016 02:54 AM
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 07:19 PM
Rod knock or Main bearing knock? jabranko General Yaris / Vitz Discussion 27 08-05-2011 12:14 PM
