Old 07-06-2006, 11:39 AM   #1
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
Upgrading from Non-Power to Power
Yeah, maybe I should have waited but here goes...
My Yaris hatch doesn't have power windows or locks. Can you get upgraded and if so, does anyone know of a price? Thanks in advance for the help.
Ran Kizama is offline   Reply With Quote
Old 07-06-2006, 03:54 PM   #2
SamDaYarisMan
SamDaYarisMan's Avatar
Drives: meteorite liftback
I don't know about an oem upgrade but i installed a universal power window kit last week from a1electric.com. I ordered the colibri star power window kit for about $150 shipped. Pretty excellent kit for the money. It came with nice flush mount, illuminated switches and plugs for the crank holes. I would think anyone who has some mechanical and electrical skills would be able to install these in an a day. It took me about 4 hours to do both doors. They also have a power door lock kit with keyless entry for $115 that i plan get also. will take pictures if anyone is interested.
SamDaYarisMan is offline   Reply With Quote
Old 07-06-2006, 04:03 PM   #3
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Pics and a link would be great!
Old 07-06-2006, 04:43 PM   #4
SamDaYarisMan
Here's the link: http://www.a1electric.com/Merchant2/...duct_Code=Star
I just went to take a pic but the batteries in the camera are dead. When i get a chance i will take a picture during the day, and at night to show the illuminated switches
Old 07-06-2006, 06:44 PM   #5
PixieDawn
Drives: Yaris 2007, Eclipse 2000
SamDaYarisMan, where in fl are you? anywhere near tampa lol..
PixieDawn is offline   Reply With Quote
Old 07-11-2006, 05:43 PM   #6
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
i've done kits like these before and they're pretty easy as long as you get the motor and all mounted securely
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 07-11-2006, 08:58 PM   #7
PixieDawn
Power Door Locks
Is this the kit on this site I would want to use for the power door locks
http://www.a1electric.com/Merchant2/...Category_Code=
Is the right one I would want to use if I wanted the alarm done at the same time...
I am going to see if i can get the door locks and windows both done at the same time since the doors will already be apart. I found a friend who rebuilds classic cars who should be able to do it for me but he wants to see the specs before he makes the deal
Old 07-12-2006, 09:57 AM   #8
SamDaYarisMan
Yes, those are the right kits pixie. Are You planning on installing this kit yourself? I'm sure you could do the door locks and windows if you have the right tools, but the alarm seems like it might be pretty difficult. Anyway, like eight heads said, the most important thing is to mount the driving gear as secure as possible to the door. If not the gears will have too much play and they will probably become misaligned and wear out. Havent had a chance to take pics, but i will probably have time this weekend to take the door panel off and show how i mounted the kit. Im in the navy in jacksonville and ill be going home to orlando this weekend. Good luck and dont hesitate to pm me if you need to ask questions about the install.
YARIS LIFTBACK: meteorite metallic, 5speed, debadged, 15" black rota gt-3's w/ 205/50/15's, tanabe df210's, colibri universal power window kit, glow shift 2" tach and twm shortshifter.
FUTURE MOD's: power door lock kit w/ keyless entry and new audio.
Old 07-12-2006, 10:51 AM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
How easy was it to remove the door pannels?
Old 07-12-2006, 02:16 PM   #10
SamDaYarisMan
Chris the door panels are very easy to remove. There are a total of 4 screws...One on behind the door opening latch and 3 underneath the armrest trim. Take the latch screw out first, then pull up on the armrest trim starting with the rearmost part. It will just pop off in 3 sections. Once armrest trim is removed you will see the 3 other screws. Remove those screws and pull the door panel away from the door starting at the bottom. You will hear the fasteners pop off. Once you've worked your way up you will feel when there are no more fasteners holding. At this point lift the entire panel up, lifting the top of the panel from where it hangs against the glass. Oh yeah i forgot, everything is really easy except for the window crank mechanism. There is some sort of flexible cotter pin type thing that holds the crank to the shaft. You have to slide two flat objects under the crank to force the cotter pin thing out. It seems to me like there may be a special tool for this, but as long as you use something strong and flat you should be able to get it out. Try to us something plastic so you do not scratch the trim.
Old 07-12-2006, 09:38 PM   #11
El Jefe
Drives: 07 yaris s sedan
you know what works really well on the window cranks is a shop rag, just fold it in half, then wedge it inbetween the crank and door panel, then work it back and forth and you'll catch the ends of that clip and pop it right out. neat trick my old shop foreman showed me awhile back.
El Jefe is offline   Reply With Quote
Old 07-23-2006, 11:02 AM   #12
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
SamDaYarisMan, and word on how that power window and door lock install went?
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-27-2006, 12:43 AM   #13
eight_heads
well i went ahead and had a new Viper alarm installed on my car last weekend, it's a 2-way and i love it.... anywho... i also ordered a power lock actuator set for cable locks for my car and will hopefully have them in this weekend...i ordered the kit from http://www.a1electric.com/cable_locks.htm and it was like $90 or so... this seems to be the only aftermarket actuator setup for cables and MES is a good brand... they are also central locking(in other words, you lock or unlock 1 door with either the key or the handle and it will lock/unlock the other door/doors as well...no need for an extra switch or button)... so i should have this kit installed and working by itself and with my Viper alarm soon...!!!
'07 Yaris Liftback
Old 07-27-2006, 02:03 AM   #14
ChinoCharles
Drives: LB
90 bucks for power locks? Please make a kickass how-to.
Old 07-27-2006, 10:46 PM   #15
eight_heads
if you follow that link they have a nice how-to on a tundra, so it should be pretty close... i may have the shop that installed my viper go ahead and do it as they warrant any install for as long as i have the car
'07 Yaris Liftback
Old 07-30-2006, 11:19 PM   #16
overboost
Drives: yaris
hey guys i Just installed my viper 791xv 2 way alarm/starter and added my own power locks. I work as a moblie elcetronics installer and this was my first attempt at putting in actuators in a car with cable door locks. I just used regular actuators and made brakets to hold the outer sleeve of the cable locks so the inner rod could be held on to by the actuator. and it only took maybe an hour per door. not to bad
overboost is offline   Reply With Quote
Old 07-31-2006, 07:06 PM   #17
eight_heads
any pics of where you mounted the actuators? the shop i am having install mine was packed this weekend
'07 Yaris Liftback
Can I add my OWN power window/mirror ? Chickon Cosmetic Modifications (Exterior/Interior) 12 07-04-2009 12:28 AM
Liftback with power package rchowelljm General Yaris / Vitz Discussion 14 06-23-2006 10:51 AM
Power Locks Uglyboyed Cosmetic Modifications (Exterior/Interior) 18 06-20-2006 11:08 PM
Power Windows Leg Room nwdixieboy General Yaris / Vitz Discussion 9 04-06-2006 07:19 AM
