Old 09-06-2007, 12:00 AM   #1
KSIbucky
KSIbucky's Avatar
Panel painting fading?
I bought paint a while back to paint my dash panels but I'm affraid to do it because of faiding or color problems has anyone experienced this i dont wanna repaint
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 09-07-2007, 02:23 PM   #2
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I painted mine but didnt like the colour / texture the first time so I repainted - must be at least 5-6 months ago now. No fading or problems so far.
mikeukrainetz is offline   Reply With Quote
Old 09-07-2007, 03:14 PM   #3
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
What brand? I guess if you want to be safe, sand but with FINE grit wet sand paper. Then primer, then put at least 3 coats of paint. Two thin and one thick. I used Duplicolor which has paint specifically for fabric or dash boards. I used it to accent the dash board. I had to repaint some cause I didn't sand, primer, reason is (well lazy) but more cause their paint has a self-adhesion promtor so you don't need to but it wouldn't hurt. They sell a separate adhesion promotor for paint. Make sure its safe for the dash. Also wash the parts you plan to paint. Cause if you paint with dust or dirt it won't stick and it will be a mess. That's what I did, I cleaned with soap the parts I did. I just repainted my center stack in my ECHO, but that's not the paint more myself. Because the first time the masking wasn't the greatest so when I pulled off the tape it took some paint so I had spots of paint that was off. So I colored it with magic marker (sharpie), yeah I'm insane but it worked cause they had the color. Since it was a small spot you couldn't tell it was marker but under certain light you can. Anyway I repainted and this time took everything that I didn't want paint on off. If you click on my username and see my garage you can see what I'm talking about. Hope that works out!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 09-07-2007, 11:19 PM   #4
phenylhydride
Drives: 2007 Yaris Sedan
Send a message via AIM to phenylhydride
Plastic can be difficult to paint. For exterior plastic parts (which are similar to interior plastic parts I'd imagine), the recommended procedures all also involve preparing the surface with this special plastic anti-static cleaner. Also the adhesion promoter is very important I'm told only if you're painting on UNPAINTED plastic parts (just the bare plastic that hasn't been painted before). Also, I'd think it'd take some time for the paint to fade from the sun noticeably with average sun exposure (like on the order of years).
phenylhydride is offline   Reply With Quote
Old 09-07-2007, 11:40 PM   #5
Ferret_san
Hack.... What hack ??
Ferret_san's Avatar
Drives: 07 YR
Plastic painting tips
Found this link @ TorqueCars
http://www.torquecars.com/styling/plastic-painting.php
Simple, basic steps. Extrract below - More info in the link....Hope it helps
Stage 1 – Preparation
Remove whatever part you plan to paint. Be careful not to scratch or damage it, you’ll only be making yourself more work.
Once you have removed the part, start by washing it with the soapy water/solvent cleaner. This removes grease, dust or any other contaminates. If there is any damage to the part, now would be the time to sort it. Next start to ‘key’ the part, making sure there are no shiny areas left on it, the better you do this, the less likely the paint it to flake later. Once you have ‘keyed’ the part, wash it again. Make sure it is thoroughly dry before proceeding.
Stage 2 – Painting
First apply the plastic primer.You may need to apply 3/4 coats of plastic primer, but you can use a hairdryer to speed the process of drying.
Once the plastic primer is dry it’s time to apply the basecoat. Depending on the colour, it may take anything from 3 to 8 coats to cover.
Apply the lacquer.Apply this the same way as the basecoat gradually building up the thickness of the lacquer.
Leave the part for a good 3 or 4 hours before you try to polish and re-fit it.
Ferret_san is offline   Reply With Quote
Old 09-07-2007, 11:48 PM   #6
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
Okay, I totally want to paint my interior now.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 09-08-2007, 12:12 AM   #7
Ferret_san
Ferret_san's Avatar
Drives: 07 YR
... and now a quick lesson on how NOT to paint the interior of your car
Old 09-08-2007, 12:53 AM   #8
black2yaris
The Man In Black Lives
Drives: Black Sand Pearl L/B 'o7
Wow that's Cool ....How'd you do that ?
black2yaris
The Man In Black Lives!
2007 2 door hatchback in Black Sand Pearl, A/T,rear spoiler,front & rear JDM badges,TRD CAI,TRD rear sway bar,exhaust tip,sill protectors,heximats,under dash blue LED's,short rubber ant,rear bumper protector,Toyota thin 7 spoke alloy wheels,pwr pkg,ABS,side curtain airbags,rear defogger,fog lights,mud guards,TYC tail lights,shift knob,tint all windows,security sys,keyless entry,clear paint protection all exposed front surfaces,TRD fuel cap,rubber dash & g/b mats
black2yaris is offline   Reply With Quote
Old 09-08-2007, 02:59 AM   #9
The airbag deployed, I think that car hit something with opened cans of paint at the back, and the force of the impact made it splash all over the place?
Old 09-08-2007, 03:07 AM   #10
Ferret_san
Ferret_san's Avatar
Drives: 07 YR
Yep..
A Guy (not me) was travelling with an unsecured load in the back (paint tins) and was involved in an accident.
In the process, the paint lids came off, covering the inside with paint.
Here another...
(Sorry KSIbucky I didn't mean to hijack your thread..)
Old 09-08-2007, 04:30 AM   #11
that's what I call making a splash!
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
AC Panel Question slvryaris DIY / Maintenance / Service 1 09-04-2007 07:16 AM
Painting my Yaris... vacantj Cosmetic Modifications (Exterior/Interior) 17 08-07-2007 04:23 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 06:27 PM
