Old 09-20-2007, 04:00 PM   #1
TRD_dude182
Drives: 2007 Yaris Sedan
Engine Braking
Do anyone know if engine braking will ruin your engine or transmission over time?
TRD_dude182 is offline   Reply With Quote
Old 09-20-2007, 04:02 PM   #2
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
If you do it wrong it can. :p
For the most part the tranny mechs I have asked all have said it's fine.
Plus the car overrides you if you shift at the wrong speed.
Old 09-20-2007, 04:07 PM   #3
TRD_dude182
sweet i just wanna make sure ive been doing it alot recently thanks!
Old 09-20-2007, 04:11 PM   #4
kurokoma-kun
Drives: 2007 Yaris HB
AFAIK if you do it right it should not be a problem.
One thing to keep in mind is that if you do it wrong (jerky), you can decrease traction, exactly the opposite of effect you may be looking for.
Old 09-21-2007, 02:36 AM   #5
Engine braking also helps save some fuel, as the ECU stops the fuel injection, as it's not needed...
Old 09-21-2007, 02:59 AM   #6
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
I'm not a hypermiler, but using engine breaking properly and with the right timing bumped my mpg up and engine breaking is just... fun.
Cheers.
blueskana is offline   Reply With Quote
Old 09-21-2007, 09:41 AM   #7
RS07
Drives: 07 Yaris RS HB 3D Black
I always brake like that and never had any problems. It also helps the lifetime of the brakes, brakes better, faster.
RS07 is offline   Reply With Quote
Old 09-21-2007, 09:47 AM   #8
staticorex
staticorex's Avatar
On a related topic...
I recently was told not to rest my hand on the shift knob. I know the potential problems this can cause on a manual, but I had never heard of it for autos.
Any validation to this?
Old 09-21-2007, 09:49 AM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I never heard of what it can cause? Can someone enlighten me?
Old 09-21-2007, 09:52 AM   #10
staticorex
staticorex's Avatar
I was told it can damage the shifter. A handfull of mechs have told me about cars they get in which the driver rested his arm there for years. The shifter was loose and could shift out of place unintentionally.
Old 09-21-2007, 09:54 AM   #11
Huh that's a new one... I suppose excessive weight on the shifter can stress some components, or if you push it to the side a little, it might disengage the gears a little, but with normal use, I doubt it's gonna be much of a problem!
Old 09-21-2007, 09:56 AM   #12
staticorex
staticorex's Avatar
That's what I was hoping. I don't push on it. Just rest my fingers there. So I didn't expect to break it. :p
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 08:16 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
CompuStar Auto Stater and Cool Engine tacsniper General Yaris / Vitz Discussion 1 08-08-2007 07:23 PM
