Old 09-25-2007, 10:06 PM   #1
caveatipse
Drives: 2007 Black Yaris
Still Confused About Gear Oil
Ok, I have a manual transmission, and I want to replace the fluid with synthetic. Do I just have to replace the "gear oil," or is there another oil I have to replace? Is "gear oil" the same as "manual transmission fluid?" Thanks!
caveatipse is offline   Reply With Quote
Old 09-25-2007, 11:34 PM   #2
caveatipse
Is Royal Purple a good choice?
Old 09-26-2007, 01:16 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
AMSoil FTW..... Royal Purple would be a distant 2nd choice
Old 09-26-2007, 01:22 AM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
I go with Redline MT90. If it weren't available I'd go with Royal Purple.
- Brian
Share the Road
Old 09-27-2007, 03:00 AM   #5
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
+1 for Redline MT90. I can't praise it enough.
My 86 mr2 currently has 298k miles. It has the same c50 transmission as you guys do. I switched to redline probably about 20k miles ago. All of my shifts became significantly easier and smoother - more of a gentle pushing into gear instead of clinking into gear. My 2nd gear also used to grind a lot, but that is 75% gone too. It's not a magic tranny fixer, but it REALLY makes a difference!!
Not to mention it's SO easy to change the tranny fluid. My car probably has 1/2 the ground clearance of you guys, and I replaced the fluid without even jacking the car up. But please be careful not to damage/strip the fill/drain bolts! Use the right size sockets!
GuySmily is offline   Reply With Quote
Old 09-27-2007, 03:10 AM   #6
man, i want to switch my gear oil now, but don't know exactly how to (and how much the oil will cost).
Old 09-27-2007, 05:23 PM   #7
GuySmily
GuySmily's Avatar
Search Amazon for MT90 - I got mine from HRP (Hoerr Racing Products), but now I see some people are selling it slightly cheaper. Approx $9/bottle.. I needed 3 quarts for my c50, but the oil capacity of the c50 may have changed in 20 years =p
The hardest part will probably be filling the tranny back up, UNLESS you can find the same bolt on the top that we use in the mr2 (it's NOT a fill bolt - it's attached to the shifter assembly somehow - but it works totally fine for filling anyway).
I can help you do it one day =p
Old 09-27-2007, 09:57 PM   #8
sweet. when i get more money, i'll let you know. thanks!
Old 09-27-2007, 10:01 PM   #9
Black Yaris
der Zeck
AMSoil was about $9 a bottle as well and it only takes 2 quarts on our 07
Old 09-27-2007, 11:00 PM   #10
NonStopTuning
My 86 mr2 currently has 298k miles...
AW11 FTW
Old 09-28-2007, 12:54 PM   #11
SDsurfrider
SDsurfrider's Avatar
Drives: 07 Sedan S
an amzoil released study sept 2007:
http://www.performanceoiltechnology....Lube_Study.htm
SDsurfrider is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
HELP! Gear Oil change on a sedan CASTREX DIY / Maintenance / Service 15 05-13-2007 04:14 AM
Which Redline gear oil is the best for our Yaris? stevencyt DIY / Maintenance / Service 0 03-13-2007 11:11 PM
