Old 09-26-2007, 09:48 AM   #1
Slummy
Slummy's Avatar
Drives: Black LB
Is it bad if....
Is it bad to switch from regular oil to synthetic and back again?
If this is a repost sorry, I'm too lazy to do search right now.
Slummy is offline   Reply With Quote
Old 09-26-2007, 12:27 PM   #2
i think it is...although i can't tell you why.
Old 09-26-2007, 12:41 PM   #3
PolarWhite
PolarWhite's Avatar
Drives: '07 Polar White Hatchback
I cannot speak for every brand out there, but I can speak for VALVOLINE since I work for them. Our formulations are all compatible with one another. You could switch back and forth between conventional, synthetic blend or the full synthetic as much as you wanted to with no ill results. I cannot tell you if that is the same with all motor oils though. Hope that helps.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads,
PolarWhite is offline   Reply With Quote
Old 09-26-2007, 03:12 PM   #4
tsportman
tsportman's Avatar
Drives: Yaris 1.8 TS
I work in a car-parts store myself and people who tell you that you can't change from fully to half synthetic or even mineral oil live in the past.
For years this had negative effects on the lubrication in the engine.
It came all down to additives wich weren't compatible to one-another.
In recent years everything has changed and nowadays you can put in whatever oil you want, or even mix different ones, although i think you shouldn't mix more than two oils.
Keep in mind to follow the constructors advice on the viscosity !
Otherwise you will reduce engine life rapidly !
tsportman is offline   Reply With Quote
Old 09-26-2007, 10:30 PM   #5
Slummy
Slummy's Avatar
Drives: Black LB
Thanks for the advice everyone. I did my last oil change myself (synthetic) but decided to go to the dealer and have them do it this time (regular). I think from now on I will just take it there. It doesn't cost much more, and I don t have to deal with it!
Old 09-26-2007, 10:32 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You can switch all you want without problems.
Old 09-26-2007, 10:34 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
That is Bull shit.... you can go back and forth from full synthetic (most synthitic are made from mineral oils), to mineral oils, to blends... to any combonation between... anyone saying otherwise is yankin your chain
Old 09-29-2007, 03:25 AM   #8
CompanyXPaladin
Drives: 08 Yaris 5-speed
I can tell you its a bad idea in a car with an older engine designed to consume oil (take... a rotary (Wankel) engined RX7). In any other car there shouldn't be a problem.
CompanyXPaladin is offline   Reply With Quote
Old 09-29-2007, 12:54 PM   #9
better to change your oil at a dealer or shop anyway, unless you have a way of safely and ethically disposing of the oil.
Old 09-29-2007, 12:55 PM   #10
for making gearhead french fries?
Anyone have bad "orange peel" on their stock paint? jdium Wash, Wax, Detailing, Exterior Repairs 30 08-05-2007 08:00 PM
Debadging Good or Bad? Anthony General Yaris / Vitz Discussion 19 05-26-2007 08:41 AM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 11:20 AM
Big Bad Oil Co. boxerboy Off-topic / Other Cars / Everything else Discussions 10 09-04-2006 12:46 PM
