Old 05-19-2009, 08:02 PM   #1
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Why my HID's are flickering???
I'm trying to install my HID's on Depo Proyectors. I follow some DIY here on the page and I didn't find any DRL Module. When I turn on the lights they start flickering. Some guys had the problem before but they don't wrote how they fix it. Any help please???
Yaris_PR is offline   Reply With Quote
Old 05-19-2009, 10:44 PM   #2
Brian
Brian's Avatar
xenon vision sells something to solve the flickering problem I think.
Old 05-19-2009, 10:55 PM   #3
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
like a relay harness?
taKuto is offline   Reply With Quote
Old 05-19-2009, 10:58 PM   #4
Brian
Brian's Avatar
I think so. It connects directly to the battery. I saw it when I was ordering my kit.
Old 05-19-2009, 11:01 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
flickering due to day time running light.. u have to use a relay and direct connect to battery instead..hid needs 12v not 10..
Old 05-20-2009, 02:21 AM   #6
rla_yaris
Drives: 2007 toyota yaris sedan
purchase a flicker relay
rla_yaris is offline   Reply With Quote
Old 05-20-2009, 02:36 AM   #7
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
or just disable the daytime running lights lol
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-20-2009, 09:15 AM   #8
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Disable your DRLs. Take the steering column cover off (3 screws) and read the how-to's again. It's very easy to do. Took me 5 minutes.
Old 05-20-2009, 11:16 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
FYI, toyota DRL runs on 12v, with a current (amperage) limiter.
to OP: you need one of these.
http://shop.ebay.ca/?_from=R40&_trks...All-Categories
Old 05-20-2009, 12:11 PM   #10
marcus
toyota
marcus's Avatar
sorry bro i checked the voltage on drl its around 10v only if i turn the headlights on then its around 12v even 14v if the engine is running. voltmeter could be wrong though.
Old 05-20-2009, 07:32 PM   #11
Yaris_PR
Yaris_PR's Avatar
Yaris here on Puerto Rico doesn't have DRL. However I check were is supposed to be and there's nothing.
Old 05-20-2009, 10:14 PM   #12
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Your power for the HID is tapped directly into the battery right?
Old 05-20-2009, 10:20 PM   #13
IllusionX
If you did it on the yaris, then you are PROBABLY right. It wasn't the case when i had the echo.
I took no chance, and installed my HID with a relay right away on the yaris.
Old 05-20-2009, 10:27 PM   #14
Yaris_PR
Yaris_PR's Avatar
Well I'm going to buy that HID relay kit to avoid any problems...thanks everyone
Old 05-20-2009, 11:48 PM   #15
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Wow strange I installed mine no problems and I installed 2 kits Headlights and fogs
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 11:21 AM
DRL Disabled If I Install HIDs? darkmoon87 Cosmetic Modifications (Exterior/Interior) 8 02-26-2009 10:34 AM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 04:30 PM
Help with HIDs!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 9 04-17-2007 01:02 PM
NEW HIDS 10000k!!!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 69 01-26-2007 01:12 PM
