![]() Drives: Yaris ts 1.5 Join Date: Sep 2009
hp vs psi
Well what do you think guys? I think that the right thing is talking about ''maximum horsepower'' for an engine component and not ''maximum psi''. I think that talking about an ammount of psi is pointless unless you are talking about a specific turbo.
what do you think? |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Yes you're right about the horsepower vs psi is based on the turbo size (among other factors). But the general rule on average is 1psi = 10hp
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
Yes
and i think that if someone is making 240hp with a T25 (20psi) it is the same thing for the engine if you had 240hp with a t28 (12psi). You have the same peak cylinder pressure during combustion if you make the same power. I think it is horsepower that breaks rods or cracks sleeves right?
No. Horsepower doesn't break rods or pistons. A bad tune or a hickup in a tune giving a spike in the air fuel causing it to run lean will blow your motor.
I do not completely agree with this. it is not only a good tune. the components of a specific engine have a limit in hp i think?
Limits... to some degree yes. I wouldn't run 20psi on stock . Longevity is more of a factor. It really depends on your hp goal.
Just to give you an idea. I am running 8.5psi with 11.1:1 compression on a hybrid gt28r turbo making over 250hp. Stock the motor makes 160hp. I could run 10psi but the egt is getting up there for continual use.
| diff. tire size should mean put diff. psi right? | ezhacker1 | Fuel Economy Forum | 10 | 01-14-2010 07:48 AM |
| Daily Driven Yaris @ 10 PSI | ChinoCharles | Forced Induction Forum | 36 | 12-23-2009 12:29 AM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 11:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 07:49 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 05:46 PM |
