![]() ![]() Drives: Yaris 2008 HB 1.5 Join Date: Nov 2009
How to reset (!) light
I was reading a similar post of this panel ligt, but is a large list of replays...
The tires are ok, pressure 30Lb like manual says, alignment and balancing ok. Can this item report suspension problem? How reset? |
Assume you're referring to this light? This light could indicate a brake problem. It also lights up if you have the handbrake engaged. Might seem like a silly thing to suggest, but do you have the handbrake released?
No, is a icon like tire figure.
You may have a bad sensor. Check out this post for instructions on how to get the TPWS ECU to flash its light to tell you what the problem is:
http://www.yarisworld.com/forums/sho...8&postcount=11
| how to reset airbags light | tonoyaris | DIY / Maintenance / Service | 4 | 07-26-2016 09:12 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| tire pressure light won't reset | nikvolkert | DIY / Maintenance / Service | 6 | 10-24-2010 04:58 AM |
| How do you reset the TIRE PRESSURE WARNING LIGHT | penny09 | DIY / Maintenance / Service | 3 | 09-26-2010 03:53 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
