Old 02-28-2011, 05:40 PM   #1
tonoyaris
Drives: yaris
Unhappy how to reset airbags light
Hi guys !!!
please help me up my 2007 yaris has both driver and passanger airbags light on and also passanger seat belt light on. I allready disconect battery for 30 minutes and nothing. please help me over
tonoyaris is offline   Reply With Quote
Old 02-28-2011, 08:08 PM   #2
severous01
you gotta go to dealer or to a shop that has the higher end scanners like snapon modis or OTC with the import and airbag kits. you can't just go get a cheapo scanner and delete it
you may also be able to get away with removing the terminals from battery and attaching them together for about 10 min. DO NOT TOUCH TERMINALS TOGETHER IF THEY STILL HOOKED UP>
Old 02-28-2011, 08:48 PM   #3
See this post for directions on how to read and then clear the SRS DTCs using just a jumper between two pins of the OBD port:
http://www.yarisworld.com/forums/sho...d=1#post557473
Old 07-26-2016, 10:10 AM   #4
Dallev
Drives: Aygo
Does this procedure work on a 2007 Aygo? The car has been powerlees for some time and now I put in a new batteri. But the airbag light keeps flashing.
Dallev is offline   Reply With Quote
Old 07-26-2016, 08:12 PM   #5
It should work on the Aygo as well.
How do you reset the TIRE PRESSURE WARNING LIGHT penny09 DIY / Maintenance / Service 3 09-26-2010 02:53 AM
How do I reset maintenance light? Snake DIY / Maintenance / Service 10 06-04-2010 12:57 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 06:10 PM
