![]() ![]() ![]() Drives: Black 07 Toyota Yaris Sedan Join Date: Oct 2009
power windows question
i used the search option to try and find my answer, but had no luck. Im installing my power windows and i need to know which power source to use. I obviously can't use the constant 12v source used for keyless entry, is there another source that turns on when the car is on?
If you used the terminal on the under dash fuse panel for your keyless entry, that same point would be fine for the window power. That tap point is a 60A capable supply, so you can use a female spade terminal that can accept 12 AWG wire and then connect two separate in-line fuse holders to it. I have my remote starter, my heated seats, and my power hatch popper all connected there with four separate fuses.
#3 | |
My seat heaters are ignition switched as well. You tap that point for the high power feed and then use a relay to switch it with the coil connected to the pink wire on the ignition switch.
oh i see. I'm pretty sure i got a good idea of what your talking about. Thanks Scott!
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 10:34 PM |
| Keyless Entry on Yaris w/o power locks question | rhumphrey205 | DIY / Maintenance / Service | 4 | 12-03-2011 07:46 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Question about air conditioning power consumption | voodoo22 | General Yaris / Vitz Discussion | 15 | 09-21-2007 01:14 AM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 08:19 AM |
