My seat heaters are ignition switched as well. You tap that point for the high power feed and then use a relay to switch it with the coil connected to the pink wire on the ignition switch.
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
