If you used the terminal on the under dash fuse panel for your keyless entry, that same point would be fine for the window power. That tap point is a 60A capable supply, so you can use a female spade terminal that can accept 12 AWG wire and then connect two separate in-line fuse holders to it. I have my remote starter, my heated seats, and my power hatch popper all connected there with four separate fuses.
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
