Old 02-13-2010, 11:28 PM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
PCV Valve Replacement
Hey guys. So the other day I was reading around about regular maintenance and I realized I never had the PCV valve looked at.
I pulled off the hose and immediately noticed oil on the end of the tip. After taking the valve off, I noticed the inside pretty dark, which is normal. However, the metal sliding mechanism did not sound good. The replacement PCV I received from Toyota clicked rapidly if you shook it, while the old one clicked only once or twice, so it seemed pretty gunked up.
I'm sure those of you with an oil catch fair better, but I am at 160,000km without one so this was a good investment. The idle also seems to be better, not sure if it is placebo but I swear it's smooth as butter now and not jumping from 500-800rpm.
BTW it cost me $18 CAD at the dealer ... rip off and a half if you ask me, but I wanted a genuine part.
devinlamothe is offline   Reply With Quote
Old 02-14-2010, 03:00 AM   #2
mimelio
Drives: NONE
I replaced my 2002 Echo PCV Valve with a NAPA Echlin for $7.10. I consider NAPA Echlin to be at least as good as OE, if not better.
mimelio is offline   Reply With Quote
Old 02-14-2010, 03:37 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
I just take mine out and clean it with carb cleaner every 20k miles or so to keep it running smooth and good. Might change it at 100k just as preventative maintanance.
Old 02-14-2010, 05:55 PM   #4
devinlamothe
Ya I think I will start cleaning it out when I change my air filter. It seemed pretty gunked up.
Old 02-15-2010, 03:03 PM   #5
Hard_Yaris
Drives: 07 Yaris
Where is the PCV located? Could anyone do a quick DIY on the location and the steps involved locating and removing?
Hard_Yaris is offline   Reply With Quote
Old 02-15-2010, 03:20 PM   #6
hatchbackkid82
Drives: .
+1
Old 02-15-2010, 05:55 PM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
take off the vvti cover on your engine. underneath that is the valve cover. on the drivers side of the valve cover there is a hose going into the back right corner that attaches to a fitting screwed into the valve cover. that fitting is the pcv valve. with the proper size wrench or maybe an adjustable you can remove it.
mikenacarato is offline   Reply With Quote
Old 02-15-2010, 06:20 PM   #8
devinlamothe
You need a 19mm deep socket to remove the PCV valve.
When I replaced mine I also put some anti-seize on the thread, since taking the original off took some force with breaker bar. Should make it easier the next time around.
Takes about 10 mins to replace.
Old 02-16-2010, 10:20 PM   #9
Hard_Yaris
Drives: 07 Yaris
Thanks for the explanation are there any photos to clarify more?
Old 02-17-2010, 12:50 PM   #10
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
What is the normal service interval on the PCV valve?
Old 02-17-2010, 02:41 PM   #11
YarisSedan
Usualy 100k
Old 02-17-2010, 06:58 PM   #12
Hard_Yaris
Drives: 07 Yaris
I found and removed the PCV Valve and cleaned it, checked it, and replaced it! A lot easier than I thought. This Forum is the greatest.
Old 03-19-2011, 03:45 PM   #13
detroiter
detroiter's Avatar
Just replaced mine today, old one had a bit of buildup on it. Seems like the new valve threads in a bit easier than the factory one too, tightened it snug but not very tight. Not sure if you can hurt the valve or engine by trying to make it very tight.
Old 03-20-2011, 11:41 AM   #14
devinlamothe
Yeah actually I just ordered a replacement, that time of year again to replace it (cheap insurance).
Old 03-20-2011, 03:15 PM   #15
Klink10
Klink10's Avatar
Cleaned mine today though it really didn't need it. Thanks for posting the reminder.
Old 03-09-2013, 05:38 PM   #16
sant_ashu
Drives: toyota yaris 1.0 t3 2004
anybody having pictures to show the location n replacement of pcv valve with pics.
Toyota yaris 1.0 2004
sant_ashu is offline   Reply With Quote
Old 03-09-2013, 07:10 PM   #17
hw6515
Drives: 08 Yaris AT, 350Z GT MT
I can take pic if you need one, but is easy to find with that img in the link
http://www.yarisworld.com/forums/showthread.php?t=43903
hw6515 is offline   Reply With Quote
Old 03-14-2013, 07:19 PM   #18
sant_ashu
please post a colored pic with some arrows that will be great.
you can post on the thread above.
cheers
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 04:05 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 08:55 AM
PVC valve routine? N9QGS DIY / Maintenance / Service 13 05-26-2009 07:32 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
