Old 05-24-2009, 01:09 AM   #1
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
PVC valve routine?
You know I am at 95K miles, I've done the plugs, transmission fluid, coolant, and oil, belt, air filter religiously over the last almost 100,000 miles , but I haven't given much thought to other items that I used to swap out on my previous vehicle, like the PVC valve and the fuel filter. Now I know the fuel filter is located in the gas tank I believe its probably not something the faint of heart would tackle, but what about the PVC valve, should that have required my attention or is there anything else under the hood that is not a fluid that may be worth just peering at? I got the air filter and belt replaced already... I guess I have felt I have done my maintenance so well that I feel I am overlooking something. My car has been great to me... Ron
198K Miles
N9QGS is offline   Reply With Quote
Old 05-24-2009, 01:22 AM   #2
Morgan
Morgan's Avatar
Drives: 07 MM LB
brakes? seems like you covered most of the wearable parts... the pcv valve can be cleaned with carb cleaner, or replaced for <$10
Old 05-24-2009, 06:35 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If you are referring to the PCV (positive crankcase ventilation) valve then its a cheap $10 pop out the old one put in the new one type of fix.
Old 05-26-2009, 09:11 AM   #4
hatchbackkid82
Drives: .
sorry to sound like a noob but where exactly is it located at?
Old 05-26-2009, 09:50 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
searches are good for you :)
http://www.yarisworld.com/forums/sho...&highlight=pcv
Old 05-26-2009, 10:40 AM   #6
hatchbackkid82
Drives: .
nice... it never gets old
Old 05-26-2009, 10:42 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
the fact that people never search before asking?
i agree
Old 05-26-2009, 10:44 AM   #8
hatchbackkid82
Drives: .
Na your smart ass remarks are what get old.
god forbid someone ask a simple question that requires a simple answer.
Old 05-26-2009, 10:48 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
i gave you a simple answer, as well as a link to a thread with pictures what's the problem here?
Old 05-26-2009, 11:26 AM   #10
jambo101
jambo101's Avatar
Post number 16 in Tomago's link shows where it is located.
Old 05-26-2009, 05:05 PM   #11
SilverGlow
Drives: 2007 Yaris Hatchback
So what he didn't search? You gonna sue him or what...no need for being a jerkoff. Just answer the question, or don't answer the question, but for F's sake let people ask away without searching...big deal get a life.
SilverGlow is offline   Reply With Quote
Old 05-26-2009, 05:26 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
who's overreacting now lil man lol
Old 05-26-2009, 07:13 PM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
wow, no need for everyone to blow up. I thought his comment and link suggestion were plenty appropriate. If you DO use the search, you get alot more info that has already been covered.
Old 05-26-2009, 07:32 PM   #14
seth_man
seth_man's Avatar
Drives: 08 Liftback
you didnt mention brake fluid. if you havent done it already, change it. every 3 years or 30k should be good if you dont race the car.
seth_man is offline   Reply With Quote
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
anyone with p90x.....i need help with routine severous01 Off-topic / Other Cars / Everything else Discussions 11 05-06-2009 07:29 AM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 12:34 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
PVC Intake spkrman Performance Modifications 16 11-29-2006 05:19 AM
