Old 07-25-2012, 04:18 AM   #1
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
power windows question
i used the search option to try and find my answer, but had no luck. Im installing my power windows and i need to know which power source to use. I obviously can't use the constant 12v source used for keyless entry, is there another source that turns on when the car is on?
A1phazu1u is offline   Reply With Quote
Old 07-25-2012, 07:05 AM   #2
If you used the terminal on the under dash fuse panel for your keyless entry, that same point would be fine for the window power. That tap point is a 60A capable supply, so you can use a female spade terminal that can accept 12 AWG wire and then connect two separate in-line fuse holders to it. I have my remote starter, my heated seats, and my power hatch popper all connected there with four separate fuses.
Old 07-25-2012, 07:49 PM   #3
A1phazu1u
A1phazu1u's Avatar
The only issue with that is the power windows still work when the power is off. A perk for some but I would like them to not work unless the key is in the ignition like most cars.
Old 07-25-2012, 08:01 PM   #4
My seat heaters are ignition switched as well. You tap that point for the high power feed and then use a relay to switch it with the coil connected to the pink wire on the ignition switch.
Old 07-26-2012, 01:49 PM   #5
A1phazu1u
A1phazu1u's Avatar
oh i see. I'm pretty sure i got a good idea of what your talking about. Thanks Scott!
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Keyless Entry on Yaris w/o power locks question rhumphrey205 DIY / Maintenance / Service 4 12-03-2011 06:46 PM
Question about air conditioning power consumption voodoo22 General Yaris / Vitz Discussion 15 09-21-2007 12:14 AM
Power Windows Leg Room nwdixieboy General Yaris / Vitz Discussion 9 04-06-2006 07:19 AM
