Old 07-01-2025, 08:19 AM   #1
mehullica
Drives: Yaris 3-door
Another fog light installation problem/question
I’ve read every post on foglight installation on using
The search tool. I just want it to work OEM style with low beams only. I have a wire harness for the on/off switch that has different color wires than anything I’ve seen. the red with yellow tracer wires, pins 1 & 3 splice together. Green wire has a crimped remake terminal, black has a ground ring terminal. I followed one installation instruction & ran wife 1 & 2 from the switch harness to the steering column D4 connector, pins 3 &4, install the fog relay. Dash & switch lights are always on key on or off. Dogs don’t turn on if. I jump power outside in the fuse block for the 2hot bulb wires coming in from the bumper harness, the fogs work. I just have a switch wire harness that doesn’t match any others I’ve seen here. If someone can help me out as to where my 4 switch wires go, I’d really appreciate it!
Thanks!
mehullica is offline   Reply With Quote
Ebay Fog Light Rant CTScott DIY / Maintenance / Service 65 06-13-2022 12:10 PM
2013 Toyota Yaris fog light HDTechVideo DIY / Maintenance / Service 8 10-29-2017 09:20 AM
Fog light problem slolude DIY / Maintenance / Service 0 07-14-2017 11:10 PM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
