![]() Drives: 2007 Toyota Yaris Sedan Silver Join Date: Jan 2014
Cable driven throttle body on 2007 1NZ?
I did an oil change on a scion with the 1NZ the other day and they had an analog throttle body on it and was wondering if anyone had thought of converting their yaris to the same layout and, if so were there any codes being thrown about it? I'm not a fan of ETB's and much rather the old style throttle bodies.
2007 Yaris sedan 1.5 1NZ-FE With 5 speed Manual gearbox. Running a set of 205/45/R16 |
To do so requires standalone engine management, in place of the ECM, as the drive by wire throttle is a key input (via a dual circuit) to the ECM and without it being present the ECM will not feed the injectors. On Garm's turbo Yaris he had done the cable throttle, but he was running standalone management.
With the stock ECM the only way to make it work would be to feed the ECM a pair of fake accelerator pedal sensor signals relative to the throttle position sensor on the throttle body. This is doable, but would require some development to do.
+1 - won't work without changing using a standalone ECU.
Thanks for the response guys. Guess I'll stick to the fly by wire system then.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
I've thought about making my yaris think it is a toyota echo.....convert to throttle cable and non-abs brakes.
What all does the ecm control? ...what would you loose if you ran a yaris with the echo ecm? |
#6 | |
If there is enough interest and a commitment to the interest, I would be willing to develop the interface necessary to allow a cable throttle to work with the stock Yaris ECM.
#7 | |
2ZR swap. DO IT! Ask how!
At the moment, the only benefit of drive-by-wire that I can see is automatic idle adjustment to prevent stalling when creeping/cruising at low speeds without having to ride the clutch. Granted, I'm OK with lots of clutch action to regulate it myself, but a more aggressive spring plate may be in my near future and that could become a nuisance. I suspect that the DFCO jerk would also become much more pronounced when slamming the butterfly closed, no? Either way, I'd love to participate in developing/prototyping this system. |
#8 | |
I can think of traffic situations where it could cause an accident. That the government, with all its "safety" laws like airbags, ABS etc hasnt made the manufacturers stop making an obviously defective feature is hard to understand. ![]() No wait I do understand it. The government is an IDIOT!
I'm pretty sure it all has to do with stability control. The car has to have the ability to over-ride driver inputs.
How different is a cable-driven throttle to a DBW with a throttle controller? I think the latter is better because I get to tweak the sensitivity depending on traffic conditions...
All I can say is drive an ECHO. It doesnt need tweaking.
play every day
Man, I totally understand...
![]() I went from a cable operated throttle body on my 1996 Tacoma (just like the Echo) to the drive by wire on my 2012 Tacoma and the difference is night and day. I really miss the immediate positive linearity of the old cable system. And it was immediate in both directions on and off the pedal. Greg |
My throttle controller really minimized the lag to the point that it's basically imperceptible... Plus I get to increase said lag to help with fuel economy when the tank's almost empty.
Don't get me wrong, I'm all for trying out new things... But is it really better not to have the option to adjust throttle response based on different conditions?
play every day
#16 | |
However, not to knock throttle controllers, my NTD one developed "Limp mode" issues, and throwing CEL for like throttle position voltage too low or something along those lines, meaning the car, just says, "throttle is giving weird signals, better just disregard what its tell the engine to do" Least limp is much safer than uncontrolled acceleration.
That doesn't really answer my question, though... Have you tried a throttle controller on your Yaris yet?
#18 | |
Im strictly a stock owner. No springs, mags, turbos or sway bars for me!
| Tags |
| body, cable, electronic, thottle |
| 1.8L throttle body dimensions drawing | CrankyOldMan | DIY / Maintenance / Service | 5 | 03-09-2016 10:30 PM |
| Cable throttle body | Crazy Butcher | Performance Modifications | 23 | 01-24-2013 01:31 AM |
| Throttle Body spacer? | jekqmb | Performance Modifications | 2 | 10-05-2011 12:02 AM |
